05-01-2017, 08:06 PM | #1 |
Carpe manana
What's that non-hardening putty stuff used for seat belt bolts to pan?
No luck on thread searches. Am chasing the non-hardening compound/putty that GM used on the threads for seat belt bolts to floor pan. What's that stuff called? Thanks, Pete.
05-01-2017, 09:52 PM | #2 |
Re: What's that non-hardening putty stuff used for seat belt bolts to pan?
3m "Strip chalk" https://www.summitracing.com/parts/t...FQ4aAm0b8P8HAQ
It's used all over the place, heater box to the firewall for instance, good stuff to have around for sure. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
05-01-2017, 10:20 PM | #3 |
Carpe manana
I saw that but didn't make the connection to the floor - OEM stuff was an off-white color. Thank you!
05-01-2017, 10:28 PM | #4 |
I don't know about an off white color that did the same thing. Hopefully we are on the same page. Strip-caulk is most certainly the most common used for what it sounds like you are talking about. A soft, not hardening seal. Under washers on bolts, master cyl covers on the floor, that sort of thing. Anywhere that you need a seal but will be removing it at some time do you wouldn't want something that hardens.
Brian
