Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-08-2017, 09:09 AM   #1
jbarron
Spray gun filter size and 2K high build primer
When spraying 2K high build what gun filter should I be running,
200, 300, 600 micron?
Don't want to clog a filter or a gun.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 05-08-2017, 06:24 PM   #2
bs46488
Re: Spray gun filter size and 2K high build primer
I didn't use the filter inside the paint gun.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 05-08-2017, 11:43 PM   #3
72HuggerK20
Assuming that you'll be sanding the 2k anyway, you need to run a filter. More of a hassle than they're worth.
72HuggerK20 is offline   Reply With Quote
Old 05-09-2017, 08:20 AM   #4
jbarron
I'll run a test with and without and see what happens.
Old 05-09-2017, 09:16 PM   #5
hugger6933
You will be fine without the filter as long as you tear down the gun to clean it anytime you mix anything and put in the pot. I buy from O'reillys I 'm sure other carry this or similar, it is called Naked Gun and it is a spray gun cleaner. That stuff is great and it is cheap and will clean your gun really well. MAKE DOUBLE SURE that you use glasses [as in the safety kind] when using this stuff I almost got some in my eye one of the first times I used it
hugger6933 is offline   Reply With Quote
