Old 05-23-2017, 04:59 PM   #1
tjc
tjc's Avatar
gasket or no gasket
I am putting factory exhaust manifolds on my newly rebuilt 454, and my engine builder said I should bolt direct to heads no gasket. What are your thoughts on this?
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 05-23-2017, 05:35 PM   #2
geezer#99
geezer#99's Avatar
Re: gasket or no gasket
If they are new you don't need a gasket. If used then use a gasket. Used might not be perfectly flat.
geezer#99 is online now   Reply With Quote
Old 05-23-2017, 05:39 PM   #3
kwmech
Metal to metal. I always butter the face of the manifold and the bolts with antiseize.
Old 05-23-2017, 06:41 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Non of my V8's with factory manifolds ever had a gasket. A good machine shop will face them flat if they are weathered or pitted at a nominal charge. Worth doing it and not having to mess with burned gaskets.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-23-2017, 06:46 PM   #5
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
As noted above, as long as the head mating surfaces and the cast iron manifold surfaces are flat and scratch/nick free, no gasket is necessary. I have used the copper based high temp anti-seize to good result. I am currently using a trick I picked up from this forum for header bolts, wrap the bolts with Teflon pipe tape and they will stay tight and not back out until you put a wrench on them. I have also used a copper based high temp rtv silicon in place of a gasket where questionable wear and corrosion were visible to good effect. The factory did not use exhaust manifold gaskets, but they isolated the cast iron manifolds with spring loaded donut gasket connections that allowed some flex reliving the stress that often compromises the head to manifold connections. I have taken my rams horn manifolds to the machine shop and had them resurfaced to true the surfaces on castings that had leaks that went unchecked allowing the mating surfaces to corrode.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Thread Tools
Display Modes
