Old 05-24-2018, 03:15 PM   #351
CRGRS 66
CRGRS 66's Avatar
Re: CRGRS 66 – Winter Build Thread
I did the lines on my truck. I have done to big tubes on the garbage trucks, but generally the guys do these.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 05-28-2018, 09:56 AM   #352
lower50's
lower50's's Avatar
Nice job they look good.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 06-06-2018, 05:04 PM   #353
markeb01
Senior Enthusiast
markeb01's Avatar
Beautiful tubing work! Congrats!!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-09-2019, 03:14 PM   #354
CRGRS 66
CRGRS 66's Avatar
Update!
The last work that I did on the truck was the brake lines, haven't touched it in forever. So, she is for sale, and just like that, it is sold to one of my closest friends.
Steve will be taking over from here. I will live vicariously through him from here on. We are actually moving the truck to his place tonight. I will sign in and catch up on all of you guys from time to time.
Cheers to all!
Craigerrr
Old 08-01-2019, 12:09 PM   #355
66c10Steve
66c10Steve's Avatar
Well, I'm the Steve that bought the truck from Craig and will be picking up where he left off. I know I have a long road ahead of me but I'm looking forward to having this baby rolling someday.
I've been peeling through everyone's builds and see a lot of impressive work and I'm sponging it all up.
I'll be sharing progress through this thread since it holds the beginning of the truck's restoration life. There's still a ways to go and it all seems daunting at times but to paraphrase a line from Johnny Cash, I'll do it one piece at a time.
Cheers fellas, I look forward to contributing to the board.
To start things off, here is where she currently rests:
Check out my 66 C10 build here: http://67-72chevytrucks.com/vboard/s...d.php?t=546694
Look here, I also built a canoe: http://stevescedarstripcanoe.blogspot.com/
66c10Steve is offline   Reply With Quote
Old 08-06-2019, 10:13 AM   #356
Android04
Android04's Avatar
Best of luck
Android04 is offline   Reply With Quote
Old 08-19-2019, 09:54 AM   #357
66c10Steve
66c10Steve's Avatar
An ever so small amount of progress this weekend.... I previously extracted a broken bolt from the nose of the crankshaft and this weekend I reassembled a few items. After ordering a harmonic balancer install tool from Amazon (since no stores in town had one to rent or buy) I was able to reinstall the harmonic balancer and then continue with the crank pulley, the fan, and the belts including adding anti-seize to the metal to metal connections.
One question I do have is, how close can the belts be to other items? I'm a bit concerned with the clearance between the belt coming from the alternator and one of the bolt heads for the power steering pump bracket as there is only about 1/16" clearance.
Old 08-19-2019, 11:36 PM   #358
Captainfab
60-66 Nut
Yeah a 1/16" is a bit close. Most of the time on a long belt like that the movement will be up and down, but they can move a little side to side. About all you could do if there is contact is remove that PS pump bracket, counter sink that hole and install a allen socket flat head bolt.
Old 08-20-2019, 07:04 AM   #359
66c10Steve
66c10Steve's Avatar
Good idea! thanks
Old 08-20-2019, 09:54 AM   #360
Robert Haas
Take off the bracket and counter sink the hole the bolt goes through. Then use a countersunk Allen head bolt to replace the hex bolt you currently are using.
Robert Haas is offline   Reply With Quote
Old 09-02-2019, 12:57 PM   #361
66c10Steve
66c10Steve's Avatar
Getting frustrated and could use some advice....
I'm trying to install the new rag joint and it does not seem to want to fit on to the shaft of the power steering gearbox.....am I missing something here or should I use a hammer and smack it on? They look like the same number of splines but it's hard to tell for sure and impossible to count on the rag joint.
Old 09-02-2019, 03:48 PM   #362
66c10Steve
66c10Steve's Avatar
I think I figured it out....the PO picked up the wrong rag joint coupling. Just ordered a Dorman 31015 to fit the 13/16 x 36 spline shaft.
Old 09-11-2019, 05:20 PM   #363
rusty76
rusty76's Avatar
Glad to see you keeping this thread alive.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 09-11-2019, 07:05 PM   #364
66c10Steve
66c10Steve's Avatar
Thanks! Got the new rag joint and installed it...fit like a glove - glad I didn't try and smash the other one on! Just sorting out the steering column and associated parts now..... gotta say, it's a hell of a disadvantage not being a mechanic or having the knowledge from disassembling the parts! No worries though, I'll figure it out
Old 09-12-2019, 09:30 AM   #365
lower50's
lower50's's Avatar
One piece at a time.
1951 MG TD
Old 09-21-2019, 07:00 AM   #366
The Rocknrod
Moderator
The Rocknrod's Avatar
Any progress?
I'm interested to learn what size fan (p/n?) and fan clutch you used?
Old 09-23-2019, 09:01 AM   #367
66c10Steve
66c10Steve's Avatar
Originally Posted by The Rocknrod View Post
Any progress?
Not too much lately (busy with family, work, kids sports, etc.) however I did decide to start stripping paint from the dash....I'm digging the bare metal look actually and if I can get it the way I am envisioning it then I may run with it....but I'll update on that once I get it where I want.
As for the fan size, I'll have to get back to you on that but I'm 99% sure the fan clutch is this one:
https://www.summitracing.com/int/par...make/chevrolet
Sept. 24th edit: Measured the fan last night, it's 19" diameter 6 blade.....don't have a part number unfortunately but hope that helps.
Old 06-08-2020, 04:47 PM   #368
66c10Steve
66c10Steve's Avatar
Well, I hadn't touched the old girl since September last year but the itch has been there lately to get back to it.
So, I finally got around to addressing the power steering bracket bolts using Captainfab and Robert's suggestion - drilled out the bracket with a countersink bit and installed 3/8"-16 x 3 1/2" long socket flat heads and it looks much better now.
I've also ordered a chrome steering column with tilt from ebay and next plan to order this seat cover in Black/White from USA 1 Industries: http://www.usa1industries.com/1960-6...ntal-band.html
I've debated for a while what colour scheme to go with on the interior but I think I'm settled on white with black & chrome/polished steel accents here and there.
I'm kind of all over the place with the order of what to do next but I think I'm going to tackle the conundrum that is the clutch linkage issue Craig brought up on post #334 on page 14....
Old 06-08-2020, 07:01 PM   #369
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Hi Steve!
I'm happy to see that you're continuing on Craig's "many winters build thread". I haven't been active on here for quite a while, but I'm hoping to get something happening again soon. We should meet up some time if it's ever safe to do so. lol
Re: your clutch pivot ball issue. I think you probably need something like this:
https://sdparts.com/i-24074894-sdpc-...nd-trucks.html
https://www.jegs.com/i/JEGS/555/601026/10002/-1
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 06-08-2020, 07:29 PM   #370
66c10Steve
66c10Steve's Avatar
Originally Posted by Johnny_Lamebridge View Post
Hi Steve!
Lol - the "many winters" build thread....quite true.
Thanks for the links - will look closer at them to make sure they'll work for the sbc.
In the meantime, I'd love to pick your brain to help me figure out a build plan....I'll wear a mask even to ensure adequate anti-COVID requirements. Shoot me a message and I'll send you my cell number so we can make plans.
Old 06-11-2020, 11:09 AM   #371
66c10Steve
66c10Steve's Avatar
2 questions for you gents today:
1. Does anybody have a recommendation for the Ivory-Off White exterior colour in rattle can form? I searched the site and came across two, one said Rustoleum Gloss White and another said Krylon Gloss Ivory. Just wondering if someone could confirm those or offer something else that they successfully matched up with.
2. Looking for suggestions on how to fill a bunch of holes that used to be from a tonneau cover.....was thinking of drilling them out using a countersink bit and then filling with JB weld but maybe there is a better method.
Here's a pic of the holes that go all the way around the bed:
Old 06-11-2020, 09:32 PM   #372
Captainfab
60-66 Nut
The correct way to fill those holes is to weld them up, sand them down, a skim coat of filler, prime and paint
Old 06-12-2020, 05:37 PM   #373
pdxhall
pdxhall's Avatar
I agree. weld them up.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 06-15-2020, 08:06 AM   #374
66c10Steve
66c10Steve's Avatar
Thanks guys - I do have a mig welder so it sounds like I'll be putting it to use. Found This YouTube Video for a technique....hopefully this is right, will definitely practice on a scrap piece of metal.
Side question, do you guys know what gauge steel the body panels are made from on our trucks? Did a search on here and it sounds like people say between 18-20 gauge.....
Old 06-15-2020, 09:27 AM   #375
cwcarpenter98
cwcarpenter98's Avatar
Most of the original metal was 19 gauge. That's also what a lot of the patch panels are
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
