12-17-2018, 09:56 PM | #1 |
How much should a batterys voltage drop once you turn off the engine?
How much, if any, of a drop in voltage should you see in a battery once you turn the engine off? My 3 month old battery keeps dying and I can't find a draw anywhere so I disconnected the battery and within an hour it went from 12.50 volts to 12.35 volts. I don't know if theres an acceptable range or if it should hold steady.
1968 C10 |
12-17-2018, 09:57 PM | #2 |
Re: How much should a batterys voltage drop once you turn off the engine?
Have it load tested at the auto parts store. A new battery should stay up to at least the 12.5v
Curious what brand etc? |
12-17-2018, 10:03 PM | #3 |
Its a cheap Walmart battery. An aside question: Once a battery reaches a state of being undercharged as mine is, does that somehow cause the battery to want to just continue dying even without any load on it?
1968 C10 |
12-17-2018, 10:07 PM | #4 |
You probably have a dead cell and the reason it looks ok for a bit is simply residual energy. The second you apply a load it will base out to the true charge state. Try returning it and get a quality battery.
12-17-2018, 11:14 PM | #5 |
It really depends on whether you have an always hot lead hooked up to a radio/ clock or something like that. Normal voltage in my '89 is between 12 and 12.2 VDC. The real test is not having a voltage drop below 9 VDC when you try to start your engine.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
12-17-2018, 11:17 PM | #6 | |
It's called deep cycling and some batteries won't survive a lot of that practice. I think some of the car stereo guys like deep-cycle batteries so they can run their music with the engine off and can run their batteries down and recharge with little problem.
12-17-2018, 11:30 PM | #7 |
Who Changed This?
A fully charged battery is 12.6 Volts. If your battery drops below this voltage even when disconnected, it is defective. It should not continue to drop voltage when disconnected. You may see minor drop because of the trickle draw for a radio to keep it alive, if it has a memory and a clock, if it is connected.
12-18-2018, 02:42 AM | #8 |
I dealt with wet cell and glass mat batteries in commercial use for thirty years. There are a lot of reasons batteries can lose voltage and not be defective. Extreme heat for one; it kills batteries. Ask anyone in the know in Arizona. Two years tops on batteries. Batteries have the longest life if kept at seventy degrees. Is that possible for the life of your battery? Probably not. This is one piece of equipment that tends to be forgotten about; including me, and all of a sudden there's a problem to deal with.
12-18-2018, 08:12 AM | #9 |
Old member
Car batteries are for cranking the car. They are not for running accessories. They don't like being discharged and they don't take well to being left discharged for long times. The alternator is for running all the accessories in the car to keep the battery fully charged.
The chart I posted is a good starting point for new batteries. So looking at the chart a 12 volt battery is fully charged at 12.73 this is at least 6hrs off the charger. Take and charge the battery as fully as possible. Take it off the charge and let it sit for at least 6 hrs with nothing hooked up to it. After 6 hrs take a reading if it's not close to the 12.73 it's on the bad side. The older the battery the less charge it will take. This is for your 3 month old battery. I use this chart all the time for golf cart batteries which I have been doing now for 30 years.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-18-2018, 11:10 AM | #10 |
It's also POSSIBLE but unlikely that you have a shorted diode in the alternator. If so they'll run hot (the alternator I mean), not charge well, and burn power once turned off. But I'd suspect at a faster rate than what you describe.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
12-18-2018, 11:12 AM | #11 | |
12-18-2018, 11:27 AM | #12 |
Old member
12.6 isn't fully charged on a 12 volt new battery. If the battery is defective it will loose charge just sitting disconnected over a period of time. It want happen over night though. If you charge a battery up good and take it off the charger while having a voltmeter hooked to it you will see it will start dropping voltage as soon as the charger is turned off. This is a surface charge and that is why you let it sit for at least 6hrs to see what the full charge will be.
The chart I posted is what all the battery manufactures go by when servicing a warranty for their batteries.
12-18-2018, 01:15 PM | #13 |
I'll just tell you, Walmart is the worst place in the world to buy automotive batteries. They don't honor their warranties very well. If you take it in, they'll tell you it needs a charge (even if it's been on a charger overnight). Then they'll want to put it on their charger and load test it immediately after they pull the charger off. Most batteries will pass under those conditions.
I took the Walmart battery that was in my wife's Highlander Hybrid to Walmart; they tried to tell me the alternator was bad (hybrid cars don't have an alternator). I ended up taking the battery home and killing it chemically and then returned it 2 months out of the free replacement warranty. They offered me about $30 back on a $120 battery. So I bought a new battery, then returned the new battery and went to Costco to buy a much better Interstate battery for $78. Bottom line: Don't buy batteries from Walmart.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-18-2018, 01:20 PM | #14 |
My BMW was at the dealership and needed a new battery, which was like $350 and was some giant Interstate unit. When it died, 1 year in and still under warranty, I called Firestone (the local Interstate dealer) to see what to do.
They said to bring it in. I said it was a warranty claim so I didn't have the receipt, but the little circles you pop out marked the date. He said that was fine, come on down. Of course when I got there the manager wanted a full documentary paper trail. I made them call the BMW dealer and sort it out, because he said if I had run up enough MILEAGE (the car has 10,000 miles total) on that battery, it might be void. So they had to get in contact with BMW in order to ensure that, I guess, I didn't start with -90,000 when I bought it. All in all, good battery, but annoying resolution process.
12-18-2018, 01:28 PM | #15 | |
12-18-2018, 04:57 PM | #16 |
Who Changed This?
12.6V is what I was taught a long time ago. I can always be educated. I found a site that has some excellent information-
https://batteryuniversity.com/ I'm going to do some reading there. They show ways to keep your battery alive longer. As Andy says, they don't like being drained. I replaced the alternator on my truck because the front bearing was noisy, and I couldn't manage to get the rotor out of the front frame. A couple of days later the battery was zero volts! Bad diode, based on the alternator getting hot while I was charging the battery. I wonder how much life that took out of my new(ish) battery.
12-18-2018, 06:18 PM | #17 |
You should be able to put an ammeter inline easy enough to see if there is any current being drawn from the vehicle while it is off.
Stupidity was meant to be painful! |
12-18-2018, 11:30 PM | #18 |
Who Changed This?
Yup. In general, these trucks had nothing to drain the battery, back in the day. Add a digital radio that will display the time and needs to be constantly on, etc., and before you know it, you have a battery-eating truck. My wife has a '15 KIA Soul. The battery went dead several months ago. I have an inductive ammeter (just place it against a wire to detect the current flowing) and it showed 6 amps flowing. All the electronics suck the batteries down pretty fast. The service manager at the dealer told me that the batteries generally only last two years in their vehicles. Based on what I have read at the source I posted above, it would be advisable to buy a float charger. I'll be buying one soon, for that reason. The question I'll have to get an answer for is if the amount of money I pay for electricity to make a battery last one or maybe two more years costs less or more than the early replacement price of the battery. If the charger and the electricity I pay for is more than the difference in the battery price, I'd be wasting my money.
