Old 04-30-2015, 10:19 AM   #1
chase@ridetech
chase@ridetech's Avatar
RideTech HD four link four your 1 Ton Build
Heavy duty trucks are the perfect application for an air suspension. The weight load of these truck can vary by several thousand pounds from trailers, people, or other cargo. With a traditional leafspring suspension you are forced to endure a harsh ride quality when unloaded in order to accommodate any anticipated cargo when loaded. With air suspension, however, you can adjust the spring rate via air pressure to be appropriate for any cargo load, light or heavy!
The new HD 4 Link rear suspension will fit a wide variety of heavy trucks. The HD 4 link offers a huge improvement in not only ride quality, but also load capacity and handling performance as well. By virtue of its highly adaptable design and weld-on installation, it will fit a wide range of 1/2 ton to 1 ton trucks.
The HD 4 Link features 1.5" diameter .188" wall DOM tube 4 Link bars, large durable poly bushings, 2" diameter .250" wall tubing bridge, .250" thick plate steel brackets, and Firestone airsprings with a total load capacity of around 7,000lbs.
Popular options for the HD 4 Link include the new RideTech impact forged Monotube shocks, your choice of universal or model specific panhard bar kits, and a variety of compressor and control systems to fit any budget or performance level.
Check them out here:
http://www.ridetech.com/store/universal-hd-4-link.html
chase@ridetech is offline   Reply With Quote
Old 04-30-2015, 09:04 PM   #2
duallyjams
duallyjams's Avatar
Re: RideTech HD four link four your 1 Ton Build
bought my truck in April 2002
by May 2002 I installed ride tech, the rear is 4 link, different kit but pretty similar, 13yrs later still loving it
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-01-2015, 07:45 AM   #3
Advanced Design
Advanced Design's Avatar
Chase, do you have any installed pictures or installation articles you can link us to? Thanks.
Advanced Design is offline   Reply With Quote
Old 05-05-2015, 09:53 AM   #4
chase@ridetech
Attachment 1397699
Attachment 1397701
Looks good! We have over 300,000 miles on one of our rigs here with the Ridetech HD 4-link
Old 05-05-2015, 09:55 AM   #5
chase@ridetech
I will locate some. I don't have any recent videos or articles but I will get some pics together!
Old 05-05-2015, 10:26 AM   #6
Advanced Design
Thanks, I might do something with our 88 Dually some day.
Old 05-05-2015, 10:51 AM   #7
chase@ridetech
That is a good looking truck, I am planning on doing a square fender crew cab build myself fairly soon
Old 05-05-2015, 10:55 AM   #8
chase@ridetech
I do offer a bolt on C30 Panhard bar kit to go with the HD 4 link.
http://www.ridetech.com/store/1973-1...nhard-bar.html
Old 05-05-2015, 10:57 AM   #9
chase@ridetech
I do have front kits and a variety of shock options as well!
http://www.ridetech.com/store/1973-1...nt-system.html
Old 05-05-2015, 11:38 AM   #10
chase@ridetech
Here are a few pics from one our customers using the Ridetech HD 4 link on his COE
Old 05-05-2015, 12:23 PM   #11
Advanced Design
Thanks Chase. The COE looks like a bolt on?..ok I see it is the panhard bar...
Also, just ordered one of your air supply and control packages from one of your dealers for my Burb build.
Old 05-05-2015, 07:51 PM   #12
duallyjams
duallyjams's Avatar
I can honestly say mine tows better with the air ride and rides better.
James
IG duallyjams
Old 05-05-2015, 08:41 PM   #13
Advanced Design
You have a really nice looking truck James. Did you need to do a notch?
One concern I have with doing this is frame integrity with the heavy loads a dually can take....I know, lot's of them on the roads for many miles and years.
With leaf springs, the forward thrust and vertical load forces are spread over four points on the frame wrere the leaf springs attach as designed by the GM engineers. With the four link, the forward thrust is on two points of the frame where the links attach. The vertical load is supported only at the two points where the bag brackets attach. Doesn't seem as strong as the four leaf spring attaching points.
Yeah, I am over analyzing it. Would be pretty cool to drop this truck. One more thing on the wanna do list.
Old 05-06-2015, 10:50 AM   #14
chase@ridetech
This customer made the upper frame bracket and then welded our bracket to it, in a way making it a bolt-on.
Old 05-06-2015, 10:53 AM   #15
chase@ridetech
We pulled a 48 foot display trailer with a notched frame over 300,000 miles and it did great! The best part of air on a tow vehicle is the ride quality. You can have a smooth and stable ride loaded or unloaded.
Old 05-06-2015, 10:24 PM   #16
duallyjams
duallyjams's Avatar
The ride tech kit came with a over the top c-notch, after 13yrs I have no concerns with the frame and I have used it as a truck, all my miles are over the road.
James
IG duallyjams
Old 05-08-2015, 09:21 AM   #17
travlinman
Chase.
How low will this kit get u in the rear with a c notch or step notch.?
And how low in the front if i wanted to run that front kit that is pictured up top ?
On a 91 r -30 dually?
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 05-08-2015, 09:29 AM   #18
Advanced Design
Chase, maybe you could put together and entire parts / price list for dropping a 1 ton properly for any of us considering doing that. Might be useful for the folks here. Thanks!
Old 05-08-2015, 04:38 PM   #19
chase@ridetech
Originally Posted by travlinman View Post
Chase.
Which body style is in your truck? Is it the square fender or the later 88-2000 body style?
I think 91 was the crossover year for the 1 ton.
Old 05-08-2015, 04:40 PM   #20
chase@ridetech
That is a good idea, I will put together some basic packages for the different body style ranges.
Old 05-08-2015, 05:00 PM   #21
travlinman
Chase.
My 91 r30 is the earlier square body style 73-87. 91 was the last year body for suburban, crew cab ,1ton.
Does ur rear 'kit' include Panhard bar or frame notches ?
65 Pontiac
69 swb-sold
71 lab sold
Old 05-12-2015, 10:36 AM   #22
chase@ridetech
Chase.
The kit does not include the notches or the panhard bar for that year range.
I do have a panhard bar available separate:
I don't have notches for that year though.
Overall the standard drop for the complete kit is around a 5 front and 7 rear at ride height.
The rear, depending on where you weld it in can be anywhere from stock height down to the frame on the ground.
Old 05-12-2015, 11:28 AM   #23
chase@ridetech
C30 Full Air suspension Kits with the Ridetech Coolride Front, RQ shocks, HD 4-link Rear, C30 Panhard Kit, RQ Rear shocks, and an Analog 4 way Compressor kit will start off at 3800.00
http://www.ridetech.com/store/trucks...hash=V328.V263
Let me know your year range or what you are looking for and I would be happy to put a kit together.
Old 05-12-2015, 09:06 PM   #24
Advanced Design
Thanks Chase.
Old 05-19-2015, 10:36 AM   #25
chase@ridetech
I should have taken a picture of my sleeping family this weekend to reinforce the ride quality improvements by going to an air adjustable 4 link.
On Saturday my brother was getting married just north of Chicago and on Sunday I needed to pick up an enclosed trailer in Milwaukee. I decided to take our 2004 Chevrolet Tow Rig with 300,000+ miles on it that has had our complete air suspension on it since new.
Driving up and around Chicago with my wife, my dad, and two of my little girls, All of them where sleeping and managed to stay sleeping as I dodged and hit potholes throughout the ruff terrain of the Chicago streets. I know I am biased because i work at Ridetech, but I also feel very fortunate to be able to drive something that can handle the job of pulling a trailer with ease and still have a better ride quality loaded or unloaded than most new cars.
