Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-28-2014, 03:22 PM   #126
sockalaminski
Re: Attempting my first build 72 K5
You're doing some great quality work brother. Keep it up.
sockalaminski is offline   Reply With Quote
Old 08-28-2014, 06:00 PM   #127
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Thanks guys! I really appreciate the nice comments. It def helps keep me motivated
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 09-02-2014, 04:00 PM   #128
72K5CSTDarkOlive
Was out of town again this weekend so no progress was made.. This week I was planning on finishing the front end.
I'm wondering how you are supposed to install the steering tie rod that connects to the knuckles? Does it matter if the castle nut faces up or down?
Old 09-03-2014, 01:03 PM   #129
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Can't recall exactly - I'd guess threads-up to avoid damage. I'll check the GMC here...
Old 09-04-2014, 10:53 PM   #130
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Threads down at both the tie rod bracket and axle end...
Old 09-05-2014, 11:27 PM   #131
72K5CSTDarkOlive
Thanks, Pete. That was my original guess. Funny thing, LMC shows a picture of the castle nuts facing upwards, but I just had this feeling that's not correct.
I'm setting realistic measurable goals this weekend.
Install the tie rod, steering stabilizer, Center link arm, and pitman.. If I get through that, I will start routing the fuel lines since there's nothing to obstruct me from getting to some of the tight spots. in the very back.
Old 09-06-2014, 12:14 AM   #132
72K5CSTDarkOlive
Steering Stabilizer question for you guys.. I ordered Skyjackers Stabilizer part# 9055, which says HD OEM Replacement Kit for 1972 k5 Blazer 4x4. (minus the brackets). It came with the bushings, nuts, and tapered studs..
The studs are different than the ones that where on there before. I don't know if that stabilizer was ever changed or was replaced with different hardware/brackets than original OEM.
Skyjackers instructions:
1. Install the supplied tapered stud into the OEM tie rod.
2. Install the supplied bushing & sleeve into the body and eye of the new skyjacker steering stabilizer & attach to the OEM axle bracket using the OEM hardware.
3. Install the supplied boot over the shaft end of the stabilizer & install the supplied bushing into the shaft end eye of the new stabilizer.
4. Mount the shaft end of the stabilizer to the new stud on the OEM tie rod.
When I removed my steering stabilizer the tapered stud was not inserted through the tie rod. It had a bracket that had to U-bolts holding it to the tie rod. The other tapered stud was bolted to the axle housing.
Old 09-06-2014, 12:05 PM   #133
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's the stabilizer I've used on my 4wd's with the OEM tie rod brackets: http://www.rockauto.com/catalog/more...937&cc=1051445
Your tie rod bracket looks correct to me. The axle end does too - It's a welded integral part of the axle. No way to reuse the old tie rod bracket with the Skyjacker stabilizer? Maybe use the old bolts/castle nuts?
Old 09-06-2014, 02:27 PM   #134
72K5CSTDarkOlive
I think i'm going to try and use the old tapered studs and see if that works. I hate how all these after market parts companies say their parts are direct oem fit.
Old 09-06-2014, 02:43 PM   #135
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Can't agree more. I've tried to make due whenever poss with OEM parts but not always an option. As for parts in general, I recently had to replace a windshield washer pump. That was hard to find in a non "universal" setup. When I found a pump (US made), I bought a spare to keep on the shelf. Wearable items like gaskets I buy extras.
Old 09-06-2014, 03:45 PM   #136
72K5CSTDarkOlive
The factory assembly manual also shows them pointing down.. Now i ran into a little bit of trouble. I can get one side in, but the leaf spring is blocking the clearance in need to get the tie rod stud through the other knuckle
Do I need to loosen up one of the leaf springs to get the clearance I need or is their an easy way?
Old 09-06-2014, 03:56 PM   #137
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I can not quite get my index finger between the Monroe stabilizer linked above and the lower leaf spring on my K20 (the Blazer and GMC are not here presently). Maybe the diameter of the aftermarket stabilizer is too large?
Old 09-06-2014, 05:02 PM   #138
Dirt's72
Mike, here's pics of my set-up if it helps, I believe is oem??? Anyone?
Dirt's72 is offline   Reply With Quote
Old 09-06-2014, 05:51 PM   #139
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Aside from the stabilizer and it's bolts Derrick's pic looks OEM to me
Old 09-06-2014, 07:50 PM   #140
Dirt's72
It appears the hardware for the stabilizer that mounts to fixed axle bracket is same as what's shown on mikes picture. The stabilizer hardware on tie rod end looks different. Mike if you don't end up using the stabilizer hardware let me know. Also I will have some questions on the winch this later, just picked it up today.
Old 09-06-2014, 11:03 PM   #141
72K5CSTDarkOlive
I learned a few things today.. However, I was successful in that I accomplished installing the steering tie rod and steering stabilizer.
I used the original studs from my old stabilizer and put those in the Skyjacker stabilizer and that did the trick.. Lined up just like OEM.. The stabilizer if a little bigger ( thickness) so i was worried I wouldn't have enough clearance between the leaf spring.
So, what did learn??? Install the steering tied rod and steering stabilizer before you bolt the axle to the leaf springs.. LOL
Old 09-06-2014, 11:26 PM   #142
72K5CSTDarkOlive
Where did you find the USA made windshield washer pump? I might need to replace mine
Old 09-07-2014, 12:35 AM   #143
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looks good! Can't recall off hand where I got the pump - will try to dig out my spare and get more info. It might have been from RockAuto as well.
Old 09-07-2014, 12:37 AM   #144
72K5CSTDarkOlive
Your pics above are exactly how mine was before I tore it down. I ended up using the old tapered stud instead so I can make it work with the original brackets. Feel free to call me with any questions about the winch
Old 09-07-2014, 09:59 AM   #145
jaros44sr
jaros44sr's Avatar
Nice build so far, enjoying the read.....but, could the stabilizer be mounted to the bottom of the bracket, might give you more room. Mines apart so i have no referance.
Keep up the detailed work
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-07-2014, 11:55 AM   #146
72K5CSTDarkOlive
Thanks, Jaro
Not quite sure. I actually thought about that.. If anybody has any reference or has done this before I'd like to see some pics. However, I think overall it should be ok.
Old 09-07-2014, 12:54 PM   #147
72K5CSTDarkOlive
Center Link bolt / nut question.. When I try to thread the nut on to the center link bolt it goes on smoothly right until it the top of the nut meets the top of the threads. Without really wrenching on it it won't go down any further. I'm afraid I might ruining the bolt. Is this normal? I checked the threads and they are in good shape.
Old 09-07-2014, 02:51 PM   #148
jaros44sr
jaros44sr's Avatar
Is that one of those locking nuts that are squeezed across the flats, sortaxlooks like it to me.....i see some indentations where it could have been pressed
SAFETY FIRST
AS usual, off topic
Jim
Old 09-07-2014, 04:06 PM   #149
72K5CSTDarkOlive
Yes, I believe so. I ended up just bolting them on there anyways.
Old 09-07-2014, 10:31 PM   #150
sockalaminski
Good call. That is what is known as a mechanical locking nut. The end of the nut is "crushed to distort the thread. When you install it, it is hard as hell to get it on and even harder to get it off. It's ideal or steering systems where a loose bolt could end in catastrophe. The nut and bolt should not be reused. If you have to take it apart, it should be replaced.
