08-23-2020, 09:52 AM | #1 |
Active Member
Warning Lights
Hi Folks, My warning lights, temp and charging at the bottom of the fuel gauge don't illuminate with the key in the on position and the engine is off. They do illuminate briefly when the key is in the start position then go out when the key is released to the run position. Any ideas? Thanks, Jack
08-23-2020, 03:06 PM | #2 |
Re: Warning Lights
That is the normal behavior. During start the bulbs give you a bulb check. There is a special circuit inside the ignition switch that provides that bulb check in the start position.
08-24-2020, 12:17 PM | #3 |
Active Member
Re: Warning Lights
