08-31-2020, 10:28 AM | #1 |
Hood corner patch
How would you fabricate a patch panel for the compound hood corner? I have body hammers and a sand bag. No fancy English Wheels, shrinker or stretchers. Lots of previous damage...about 3/8" of body filler or more. You can see how far it needed to come out when I made the vertical cut. Many dent puller holes already welded up (which shrunk the metal). The portion cut out was swiss cheese and I needed access to fit the rest. TIA.
08-31-2020, 11:05 AM | #2 |
Post Whore
Re: Hood corner patch
without tools, youll just have to form it by hand...I made a cab corner for mine and I started it by hand bending it around a 4in pipe...I think I had 6-7 pieces that I welded all together... ...If you can use the good side as a pattern , itll get you close..
you can also use heavy paper to make a pattern of what you need..then transfer it over to metal...that's the way I did mine... a contour transfer tool will be a big help
08-31-2020, 11:58 AM | #3 |
I'd find a doner hood to cut the patch out for the hood your working on. Plenty of guys would be willing to cut it out for you and ship it. Just place a wanted ad.
08-31-2020, 05:26 PM | #4 |
Great idea! Will do so now. Oops, I am not a paid subscriber, so no go...
08-31-2020, 06:24 PM | #5 |
So spend a couple of bucks and support the forum you could even end up saving money
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
08-31-2020, 08:59 PM | #6 |
I agree with getting a patch from a donor hood. It will much easier and a lot less stressful.
Can it be done using hand tools sure. But you are going to have to make it in about 6 or so pieces because of all the contours involved
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
09-01-2020, 09:44 AM | #7 |
I,ve been watching this guy on u tube, he uses all hand tools except a metal brake. Fitzee,s fabrication. https://www.youtube.com/watch?v=1AiDqIHP5Po
09-02-2020, 10:59 AM | #8 | |
09-02-2020, 11:19 AM | #9 |
Post Whore
David...heres the cab corner patch I made for my IH..i dd use a shrinker/stretcher, but the rest was hand formed...a donor hood patch would be ideal for sure...but I dont see it being unmakable either....
