02-28-2017, 08:26 PM | #1 |
L31 Intake Gasket W/Carb?
I'm getting ready to install my Edelebrok Intake on my new L31 5.7 small block. (I will be running a Holley carb)
Qusetion- What is the best intake gasket to get? - Should I purchase one for a 97 5.7? Any help appreciated. |
03-01-2017, 12:29 AM | #2 |
Re: L31 Intake Gasket W/Carb?
I've run thick paper gaskets that I port matched in the past (Fel-Pro, can't remember #) After a while they would leak coolant (go figure?!) I switched to Fel-Pro MS98000T gasket set. They are metal gaskets with rubber seals. I run them on every 5.7 vortec, stock intake or not. (FYI -The set only comes with one valve cover gasket)
03-01-2017, 01:12 AM | #3 |
60-66 Nut
There is a part number that gets you just the intake gaskets that are in the MS98000T set, but I can't seem to find it now. The gaskets that are in the MS98000T set are about the best you can get for the Vortec. Yes you could spec the gaskets for a '97 5.7.....the '96-'02 Vortec 5.7's are all the same.
03-01-2017, 03:25 AM | #4 | |
03-02-2017, 12:05 AM | #5 |
60-66 Nut
This is the intake set I was trying to remember last night. All it is ,is the intake gaskets and a tube of RTV for the ends. I was mistaken though on the gaskets being the same as in the MS98000T set. These are plastic with the seal around all the ports.
https://www.summitracing.com/parts/fel-ms901312
03-02-2017, 01:02 PM | #6 |
driving is in my blood
Only run the metal with rubber sealer around the ports. All others were previous, failed versions.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
03-02-2017, 06:40 PM | #7 |
When I was building my 383 it has Edelbrock heads and intake so I ordered an Edelbrock gasket set. The package had Edelbrock on the outside and Fel-pro 1255 gaskets inside so now I just buy Fel-pro 1255 gaskets. So far no problems.
03-02-2017, 08:41 PM | #8 |
Is this the correct part number? This is what Auto Zone gave me. It's supposed to be correct without all the extra gaskets I dont need. (just not sure if it is quality or not) Can't open it or its not returnable
03-02-2017, 10:17 PM | #9 |
No, they are paper "Perma Dry" gaskets
03-03-2017, 12:29 AM | #10 | |
60-66 Nut
NO they are not the paper 1255 gaskets. See my post from above.........
03-03-2017, 04:32 AM | #11 | |
the oem plastic intake and dexaclog coolant? Or have these failed with the carbed alum intakes and normal green coolant..? I ask because if you look at all plastic intake gaskets now they are o ring rubber type around ports.. And the alum is a tad stronger than the plastic and the span between the bolts.. |
03-03-2017, 11:27 AM | #12 |
03-03-2017, 11:37 AM | #13 | |
One other thing I do with vortec intake manifolds - I try not to bolt any accessories to the manifold because the bolt torque is so low I don't want something "working" the manifold back & forth. (for example: if you run the TBI serp belt setup the A/C compressor has a brace that runs back & bolts to the intake) If I do bolt to the intake I use a stud, torque the nut down to spec. then bolt the brace down on top of that. |
03-03-2017, 05:11 PM | #14 |
They leak.
sorry had to. I have no idea what the specific failures are, only that they constantly failed and re-designed the part, twice. That's good enough reason for me.
