05-18-2018, 07:34 PM | #1 |
Replacing hydraulic clutch line
She popped a pin hole in the hydraulic clutch line right above the exhaust manafold. Does anyone have a write up on replacing the line? i bought one from GhettoZone today and i, wrongfully, assumed it was going to be bolt together like brake lines. I cant figure it out and cant find much online about how it comes apart and goes together. The ends are almost like an air hose, if that makes any sense.
1994 K1500 5.7 Manual Transmission regular cab stepside |
05-18-2018, 11:55 PM | #2 |
Re: Replacing hydraulic clutch line
Take a pic of the part. My shop manual has a line going over to the pass. side of the engine and no mention of replacing the line. Maybe it needs a tool like a fuel line removing tool, but I'm just guessing. In the F-bodies (Cam & F-birds) they had a line on the driver's side. Not sure which...
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
05-19-2018, 10:24 AM | #3 |
https://photos.app.goo.gl/oJ7Yg2bqazH9aJNx9
Heres the end that goes to the slave cylinder. The other end is the same but on a rigid plastic line. The side going to the master cylinder is blocked and looks like this. https://photos.app.goo.gl/dgxOumWTbGRczP7Q2
05-19-2018, 01:18 PM | #4 |
I can't get a copy of the picture to post from your link to show what I am trying to say, sorry if this doesn't come across too clear, but in the 2nd picture showing the line going into the bottom of the cylinder, is that a roll pin?
Maybe if it is, if you punch it out, it will release the line?
No bolt or nut in the world will remain tight if you turn it to liquid!!! |
05-19-2018, 02:43 PM | #5 |
The clutch master cyl. and the line might sell as one unit. That's the way it is with my Firebird and probably my '09 H3T. I'd return the line and try to get the whole unit. And yes, I believe a fuel line removal tool would be similar to the tool you need to remove the line. A small screwdriver might work too. Without a complete picture we're taking shots in the dark. I know a friend of mine is very clever when I pose questions like this and I can rely on his ideas.
05-19-2018, 02:49 PM | #6 | |
05-19-2018, 04:21 PM | #7 | |
05-19-2018, 05:35 PM | #8 |
True enough, always a risk with things like that. Maybe get a complete replacement unit and just be done??
05-20-2018, 08:43 AM | #9 |
I believe it is a small roll pin. I had to change out my hydraulic line when I replaced the clutch in my 93 454 truck several years back, I pinched the plastic line when I mated the trans back to the engine.
I can't remember, but I think it comes out pretty easy, I may have even used a nail to push it out .
76/77/78 Cheyenne 1997 K3500 454 soon to be 496 |
05-22-2018, 08:30 AM | #10 |
here, just not logged in
93-95 hydraulic line is non replaceable, per Haynes Manual
05-22-2018, 08:37 AM | #11 |
Yes it was roll pins. They were pretty rusted but came out with a nail and some pb blaster. Thanks.
05-22-2018, 08:46 AM | #12 |
Good to know. We see how correct Haynes is.
05-22-2018, 06:54 PM | #13 |
Reminds me of my neptune washer. When the tub bearings went out the factory manual said it wasn't serviceable, but a set of seals, bearings, and a you tube video and i had it going again for about 50 bucks!
Thread Tools | |
Display Modes | |
