05-15-2020, 09:17 PM | #1 |
Frame paint options
Im looking at getting a low sheen satin paint for my frame , just wondering what you guys are using.
Ive looked into the eastwood stuff, |
05-15-2020, 09:31 PM | #2 |
Re: Frame paint options
I have been using equipment enamel for frames and suspension parts. Holds up good. Lots of options for sources from sherwin williams to tractor supply.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-15-2020, 09:41 PM | #3 |
3 coats SPI black epoxy
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
05-15-2020, 10:42 PM | #4 |
Post Whore
"SPI black epoxy "----X2
05-16-2020, 03:46 PM | #5 |
I prefer I urethane over an epoxy. If you scratch an epoxy the rust will travel. If you use a metallic based urethane primer the rust won't travel beyond the scratch. A 2 component polyester type urethane has more chemical and acid resistance. If you're looking strictly for color is one thing if you're looking for long term corrosion resistance use the 3 coat polyurethane system
05-18-2020, 12:33 AM | #6 | |
There's no such thing as a metallic based urethane primer. Any urethane (high build) primer has zero rust prevention properties. Urethane is a very good topcoat and does have great a abrasion resistance.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
05-18-2020, 07:46 AM | #7 |
I don't know what to say. Aluminum pigmented moisture cured permanent rust sealer/primer was developed by Mo Bay chemical in the mid-seventies for bridges. When I worked in the industry I sold it regularly. This sealer primer with a polyurethane topcoat would run thousands of hours of salt spray with very little or no rust creepage if there was creepage it would be less than 1/32 of an inch. Polyester urethane. Has 10 times the chemical and acid resistance that he automotive line. It was used on subway cars all over the country.
Now you work in a body shop how many different paints did you see in a body shop? I would say probably maybe 10 different coating systems. I had to deal with a lot more than that. Go to the thread titled had to make an older restoration quickly you'll see a picture of 2 tablets one with your epoxy and one with the permanent rust sealer and see the difference. Each panel has 3 coats It downloaded Im a computer whiz |
05-18-2020, 09:27 AM | #8 |
You're obviously well intended and well informed, but sending guys out looking for the products you are talking about is not good. Industrial coatings are a whole different kettle of fish, as you described.
Check out https://www.rustoleum.com/product-ca...oatings/noxyde for bridge coatings developed in the past 10 years or https://www.sealforlife.com/product/wrappingband/ a Polyisobutane based corrosion coating are used in underground pipelines and sea structures ... both of these products boast an incredible long life service with no rust but neither are available to the general public, are offered in small quantities, are intended for automotive restoration/repair nor are affordable even if they were. My point being there are many industrial products not available or even applicable for vehicle repair which basically has one coating system; epoxy primer on bare metal, then urethane high build primer, then urethane top coat.
05-18-2020, 10:08 AM | #9 |
This Mustang is completely primed inside and out with the Permanent rust sealer primer to minimize comebacks. Vintage cars of South Carolina has done this for the last 20 years or so. This procedure is as follows 2 coats the Permanent Rust Sealer followed by epoxy or urethane surfacing primer, something sandable. There are companies in the hobby that sell small amounts of industrial coatings for restoration work. I was affiliated with a couple of these companies prior to my retirement so I hesitate to name brands.
05-18-2020, 02:37 PM | #10 |
I’m an industrial painter and also do automotive, there isn’t anything for a bridge I would spray on a car! The salt fog video you shared was made by you?
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback Last edited by projectking; 05-18-2020 at 02:44 PM. |
05-18-2020, 02:43 PM | #11 | |
05-18-2020, 03:52 PM | #12 |
I'm sorry if you were able to read what I scribbled out I'm not a graphic artist. I did not make that salt fog video It was done somewhere in Missouri or Indiana. Do you use an epoxy on your automotive work? They Use that on bridges. They use single stage urethane on bridges What do you use on chassis?
05-18-2020, 04:54 PM | #13 |
My chassis paint recommendation is already posted here. That video is by a guy that has no other entries on YouTube, it’s bull**** to promote a product. We use a wide range of products on bridges, mainly zinc, epoxy, and urethane. The only time we use all urethane based products is a moisture cured system when working in cold temp is required. There is little to no flex in industrial products making them useless against rock chips. There is no comparison between industrial and auto grade epoxy except the name Epoxy same goes for urethane. How can you compare products that are spec’d out 12 mills of epoxy before a 2.5-5 mil topcoat when a complete auto system is sub 7 mil total?
Mastercoat and the 10 or more rebranded similar products rates with the snake oil POR15 in my book. If a restoration shop uses them I’d simply find another place to take my ride...PERIOD
05-18-2020, 05:43 PM | #14 |
Well nobody called anybody a hack LOL I guess that nickname only applies to me but I’ll throw my two cents worth in SPI
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
05-18-2020, 05:49 PM | #15 |
I just saw your post with the SPI epoxy without a topcoat. That explains the attitude.
05-18-2020, 06:15 PM | #16 |
I used the $84 kit on my chassis
05-18-2020, 06:15 PM | #17 |
What does that mean?
05-18-2020, 08:36 PM | #18 |
What’s your guys take on the Eastwood 2k satin black or the extreme chassis black
05-18-2020, 09:06 PM | #19 | |
https://5starxtreme.com/ The entire Xtreme line is built from various high end automotive refinish products manufacturers on the market. I know this because I was part of the testing and development team for IAMG when the Xtreme private brand was launched. No compromise to quality was allowed for it to carry the Xtreme label.
05-18-2020, 09:44 PM | #20 |
Not sure about being a hack or not but definitely has skin in the snake oil peddling game.
05-18-2020, 10:06 PM | #21 |
Project King you been on my case from day one. This is not the 1st time that I had to deal with the thugs. And you know damn well what I'm talking about. Let's do some independent testing will split the cost if that subway paint looks like snake oil you got a lot to learn.
05-18-2020, 10:34 PM | #22 | |
05-18-2020, 10:38 PM | #23 |
Lot to learn...LMAO! I’m NACE certified among others...stick with YouTube and your discount chassis saving miracle paint.
05-19-2020, 11:34 AM | #24 | |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
05-19-2020, 12:28 PM | #25 |
It is Vintage cars Inc. Fort Mill South Carolina
Thread Tools | |
Display Modes | |
