01-30-2017, 06:27 PM | #1 |
Transmission Conversion
Hello, I need some advise. 1967 Chevy C10, 250 6 Cylinder with 3 speed manual transmission. Going to put in a 383 with a 700r4 automatic transmission. What do I need for a cross member for the transmission? I don't think the current cross member for the 3 speed manual transmission will work, but could be wrong. I want to get this done while I am painting the frame. Thanks.
01-30-2017, 11:59 PM | #2 |
Re: Transmission Conversion
You might get some responses if you post this in the 67-72 forum
02-08-2017, 10:24 AM | #3 | |
not sure if you can use the 6 cyl motor mounts on the v8 install. good luck on your project!
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
08-17-2017, 06:11 PM | #4 |
Moderator
The current rear engine mount cross member needs to be removed totally.
The V8 will require new engine mount towers and of course, new mounts. You will need a rear trans cross member, either from a 350/350 truck or aftermarket... As you realize, its a lot easier to do all this while the cab is off the chassis. |
08-23-2017, 09:24 AM | #5 |
1967 Chevy C10, 250 6 Cylinder with 3 speed manual transmission. Going to put in a 383 with a 700r4 automatic transmission. I don't think the current cross member for the 3 speed manual transmission will work, but could be wrong. I want to get this done while I am painting the frame.
