02-19-2018, 03:50 PM | #1 |
Exhaust manufold coatings
What is the best cast-iron exhaust manifold coating that you can apply yourself at home? I used some high heat spray paint, vht i think and rust is coming through. The ram horns were glass bead blasted also before paint. They were painted awhile before eng was fired and cam broke in. post up what you used and liked. thanks--------
1961 chevy K10 my build is------------61K10 build |
02-19-2018, 05:08 PM | #2 |
Re: Exhaust manufold coatings
I’ve used this stuff. The brush on type. Have had to do the odd touch up, but it lasts.
https://www.eastwood.com/factory-gra...p-coating.html |
02-19-2018, 05:16 PM | #3 |
Post Whore
not a at home project but I've had good luck getting exhaust parts aluminized coated...holds up really well
02-20-2018, 12:12 AM | #4 |
60-66 Nut
This is what I have always used on my headers with very good results. I've always had it in gallon cans but I believe you can purchase it at Home Depot and Lowes.
http://forrestpaint.com/stove-bright...aerosol-paint/
02-20-2018, 11:39 AM | #5 |
Like geezer#99, I used the Eastwood Hi temp coating. My opinion is that it is a solid DYI option. Looks good and so far has been durable.
1972 GMC Jimmy 6.0/4L65 1972 Chevrolet long bed 1/2 ton |
02-20-2018, 12:10 PM | #6 |
I didn’t think rust existed out there? I painted the manifolds on my last car build, used bbq paint and worked pretty good. They discolored some but don’t think rust bled thru...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
02-20-2018, 02:24 PM | #7 |
Thanks for the reply's. I have used something like the eastwood years ago. Might have been eastwood lol. Came in a pint can and it went a long way. Probably didn't blast the manifolds good enough as they were rusty to start with.
B454--we don't have the humidity that you have for sure. I'm at 2500' elv and get snow at times. Last year got 83" of rain. tk in garage that gets damp probably doesn't help. Have to pull them off and start over.
02-21-2018, 12:04 AM | #8 |
60-66 Nut
The prep work is very important to a lasting good finish. They must be blasted to 100% white metal to get rid of all the rust.
