02-22-2018, 05:10 PM | #26 |
Re: Gas milage help
I have a 2015 with the 6-speed. 21 is best on long drives. pulling the toy hauler... 6-10
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-22-2018, 05:54 PM | #27 |
Re: Gas milage help
If you can't afford the gas you can't afford the truck ,Buy a kia or ride passenger with someone getting 18-20 ...
02-22-2018, 10:27 PM | #28 |
Where's my beer?
Re: Gas milage help
I've heard people say the Quadrajet will actually do better on gas than a 2 barrel because the primaries on the Quadrajet are smaller. This of course only works IF you keep your foot out of it, and therefore out of the secondaries. I"ve heard this from more than one source, so I think it definitely has merit although I have no first hand experience.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
02-22-2018, 10:42 PM | #29 |
Re: Gas milage help
Is the odometer reading distance correctly? I had an odometer on my 71 C-10 that was off by 12% and it skewed my mileage. I checked it over 100 miles using GPS and highway mileage markers to confirm how far off it was. The weird thing was it was registering speed correctly, but the odometer was way off.
02-22-2018, 11:20 PM | #30 |
Who Changed This?
Re: Gas milage help
It also occurs to me that there may be a mismatch of parts, where the manifold and carburetor don't match the engine's design. But a tiny 2 bbl on a factory manifold should act like a big four barrel that just isn't opened big. My son put a single-plane manifold on his Dart with a 318 and it got $**t for mileage. A dual plane E-brock manifold yielded a significant improvement, even with the same carburetor- like 3 MPG worth.
OP, stick with us. We'll help you get it sorted.
02-22-2018, 11:50 PM | #31 |
Re: Gas milage help
Ok so I bought a used quad jet carb. Late 80’s and a new manifold and once I put that on I will let everyone know how it improves.
Also. I’m having another problem. If I’m driving some times when I let of the gas and push in the brakes the truck wants to stall. So I have to drive it like a weird Manuel pushing the gas and brakes. Thanks for the help so far. Posted via Mobile Device |
02-23-2018, 12:29 AM | #32 | |
Re: Gas milage help
02-23-2018, 08:47 AM | #33 |
Re: Gas milage help
Anyone notice the open vacuum port lower right front of carb?
Grandpa 1953 M38A1 Jeep 1989 GMC K2500 1958 Alaskan Camper all original WORK : A necessary evil that finances what I really like to do. |
02-23-2018, 09:23 AM | #34 |
Re: Gas milage help
Is this connected? If not, it's causing a huge vacuum leak and would explain why it wants to stall when slowing down.
Is the vacuum advance on the HEI plugged in?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-23-2018, 10:08 AM | #35 | |
02-23-2018, 10:49 AM | #36 |
Re: Gas milage help
02-23-2018, 01:13 PM | #37 |
This is the carb and manifold I got for the GMC
02-23-2018, 03:16 PM | #38 |
Re: Gas milage help
02-23-2018, 03:22 PM | #39 |
Re: Gas milage help
I'm gonna go ahead and stick up for Dave here. His truck is so clean and polished, that there is no coefficient of drag. The rest of us all have rust and crud anchoring us the those pesky molecules.
A plug for Dave... He has one of the nicest trucks on this forum. Now that I know it get's that kind of mileage... I really want that truck! j
White K20 |
02-23-2018, 10:25 PM | #40 |
Re: Gas milage help
Don't know how long the carbs been sitting that you bought but make sure its clean inside fuel bowl, jets and vacuum passages. Use new base gasket and don't over tighten the carb to intake, you'll warp it or strip the threads. Check your timing, a good starting point would be 8dgs btdc. What motor from jegs? Part #. What rear gear ratio, if you don't know, spin a tire one full revolution and count how many times the driveline goes around. The new motor will use a little more fuel until you get some miles on it.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
02-24-2018, 12:17 AM | #41 |
Re: Gas milage help
+1 from me. I recommend checking this in order to get an accurate take on what's going on, before you make changes. My odometer does not work well, speedometer is OK. It is very easy to check, just drive a known distance according to mile markers or along the highway and compare to your favorite navigation app.
02-24-2018, 04:18 PM | #42 | |
Re: Gas milage help
My 5.3 swap does a consistent 17mpg although I had hoped for a little better, its still better than the 350/350 quadrajet I pulled out of it that only ever got 10mpg no matter how grandpa like I drove it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-24-2018, 04:50 PM | #43 |
Re: Gas milage help
When I got my truck it had a six with the single barrel, powerglide and 3.73 gears and got around 10 mpg. I put a Edelbrock 500 cfm four barrel on the six and got around 9.5 mpg. I am now putting a 454 in it with two four barrels and an overdrive auto. Will likely get around 9.5 mpg!
1968 SWB Step Side, Big Block, 4L80E , Running! |
02-26-2018, 11:53 PM | #44 | |
Re: Gas milage help
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
02-26-2018, 11:58 PM | #45 |
Re: Gas milage help
I know it's an outrageous claim on it's face (which is why I made it!) but before you dismiss it, consider this. With a small carb on a small 283 or 307 V8, these trucks they can run just as efficiently, excluding the combustion chamber design, as the most modern vehicle, but only at one rpm and load. A modern engine can do it across the whole spectrum. But even an old engine has a sweet spot where the AFR is just right.
The problem is that the 1969 can only do that at one rpm (peak torque, ideally) and without every varying the load, lest the accelerator pump kick in. And because these things are bricks and lack overdrive you're at a painfully slow speed, like 50 mph. Make sure you also take notice that I said FLAT like flat to within 1 foot over 50 miles. The truck has to climb nothing, so the accelerator pump never strokes, the power valves never open, nothing. Essentially on cruise control. So all I'm claiming is that the old 307 can cruise at an unchanged speed like 50mph very efficiently I think. I think it can approach modern truck efficiency. But if you drive it Oregon instead of Saskatchewan, all bets are off. Climb a even slight hill and you invoke the acclerator pump maybe, or come off the cruise circuit, and it changes a lot. I sure can't think of any reason a properly tuned truck couldn't get 18mpg at 50mph but I can think of lots of reasons it couldn't get anywhere near that in most situations. So keep in mind I'm basically talking about getting 18mpg driving slowly on a pool table.
02-27-2018, 12:22 AM | #46 |
Who Changed This?
Re: Gas milage help
I'd personally be astonished if a V-8 truck back in the day got 18 MPG. The amount of wind it has to push at speed is going to be against that, at least with the technology available back in the day. These things are like slightly rounded bricks, as far as wind resistance is concerned. The computer controls these days augment the curved shapes in order to get even a small improvement. We buy these trucks to do work. Work takes energy; that comes out of the gasoline (or diesel fuel).
02-27-2018, 08:25 AM | #47 |
Re: Gas milage help
I think of it this way, I ran a small block in my truck for years and got decent mileage empty, around 12mpg but as soon as I hooked up my trailer I was fortunate to get 6mpg and I was lucky to get 1 or 2 cross country trips before I had to take it apart. I built and put in the truck's original engine, a 292 and now my mileage is crap all the time, about 9 to 9-1/2mpg but that's regardless of where I am or what I'm pulling and that engine can slowly pull the Rock of Gibraltar across the country without faltering. The old truck has been paid off for 21 years so I see no issue donating to the gas tank to have such reliability as I do.
At 6.5mpg, it's likely you just need a good tune up and timing adjustment. I've experienced that with my small block but it didn't take much for it to come up to about 12mpg-ish.
03-05-2018, 03:27 AM | #48 |
Re: Gas milage help
Ok guys. I jacked up the back of the GMC and spun the tire twice and the drive shaft rotated just a little over three times. So I’m guessing I have a 3.08 rear end. I checked and I do have a TH350 tranny. Another thing I discovered is the brakes are stiff in the back so the tires won’t freely spin. So that was one of the reasons my gas milage was terrible. But the bolts for my quad jet came in today so hopefully I can get it all hooked of tomorrow.
03-05-2018, 08:07 AM | #49 |
Re: Gas milage help
My 70 C10 with a 383/700R4 gets about 16 or so and I wish it got 10! Because then that would mean that I was holding it to the floor more often.
Brian Ritter |
03-05-2018, 08:25 AM | #50 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Gas milage help
Thanks for checking back in Awann, dont get discouraged by some of the comments. A 350 with a 350 Turbo-Hydramatic and 3:08 gears can easily get 12 mpg, with a well tuned 4MV Quadrajet. I have two 72 Chevy C/10's that started life with the same 350/350THM and 3:08 gears, one was a 2bbl the other is a Quadrajet sitting on an Edelbrock Performer intake like the one shown in your pic. Buying a used carb (like the one in your pic) will almost certainly require a cleaning and a rebuild kit. To do that you'll need to ID that carb and find out what it came off of because the choke mechanism appears to be a hot air operated choke unit. Thats ok because they can easily be converted to electric or even manually operated. My 2bbl Rochester never came close to getting the mpg's the Quadrajet did and when you look at the diameter differences between the throttle butterfly's you'll see why the Quadrajet is renowned for it's mileage capabilities. Here's a good read to get you started in ID-ing your carb. http://www.chevyhardcore.com/tech-st...ication-guide/ But before you spend another dime educating yourself and buying carbs and carb parts you should really consider what S10MK said in post #4 because by the time you rebuild or replace that Quadrajet and consider the costs involved a self programming fuel injection unit can be had and installed for little more than a properly set up Quadrajet. The FiTech and the Holly Sniper are getting good reviews, something worth considering. If you haven't already, converting over to an HEI ignition will help with mileage as well. There are a few of us die hard Quadrajet guys still kickin it and willing to help on this forum...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
