05-11-2020, 10:24 PM | #1 |
Educate me on the Insta-trac 4x4 system.
I am referencing this truck which i might purchase. 70,000 original miles.
I know I can switch to 4x4 on the fly but ... if the roads are wet - will this system operate ok? Thanks
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-12-2020, 12:04 AM | #2 |
Re: Educate me on the Insta-trac 4x4 system.
As long as all the tires are spinning the same speed, the tires are the same size,, there will be no issue. If the tires are different and are spinning at different speeds, the front axle will grind when the actuator locks the front axle
05-12-2020, 08:04 AM | #3 |
Don't need 4wd on wet roads....
05-12-2020, 09:47 AM | #4 |
On a heavy down poor - yes.
I am not talking light drizzle-no.
05-12-2020, 09:47 AM | #5 |
05-12-2020, 12:44 PM | #6 |
Except you don't want to be spinning one or both rear wheels when you try to shift anything into 4wd. Back off the gas first and don't shift into 4wd while turning a corner.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
05-14-2020, 04:37 PM | #7 |
driving is in my blood
Huh? I've never seen rain cause a need for 4wd. You don't even need 4wd half the time your off road. How can heavy rain cause a loss of traction that a light rain doesn't? Wet is wet as far as the tire and grip is concerned. If your hydroplaning then 4wd isn't going to help you steer.
As for the 4wd system, its a super basic setup. It just goes into 4wd. Not sure what problems you would anticipate having?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
