10-14-2019, 09:52 PM | #1 |
yet another oil pressure thread
6.0 swap into my 59. I tapped the "block off plate" above the oil filter to put a sending unit in. I primed the engine. then I started it. zero oil pressure. another thread before was i had a fuel injector issue dumping fuel. soaked the oil so i changed it. still no oil pressure. verified my gauge, even put a mechanical gauge into the block off port. with the block off port open i can crank the starter and get a little flow of oil coming out, when i put the gauge back in and start the motor the needle doesnt even move at all. thinking pickup tube oring since the pan was changed just throwing me for a loop that it doesnt have at least a few psi when i know cranking the starter some oil comes out.
Is there somewhere else i can install the mechanical gauge to verify before i start ripping into the engine? ive watched a million videos so if assuming oil pickup o-ring or the pump. anything else that would cause zero oil pressure?
Bagged 1959 GMC 1969 C-30 dump My 59 build. http://67-72chevytrucks.com/vboard/s...d.php?t=592878 |
10-14-2019, 10:12 PM | #2 |
Re: yet another oil pressure thread
did you drill all the way thru the blockoff plate?...dumb question I know but i had to ask..
you can use the original oil pressure sender location behind the intake...you'll need a metric to npt adapter...but this is where I hook all my oil pressure senders
10-15-2019, 09:59 AM | #3 |
I definitely drilled all the way through and the hole is roughly the same size as the hole in the adapter on the mechanical gauge. I can’t imagine that if it has pressure at all it wouldn’t show up there.
10-15-2019, 02:06 PM | #4 |
I've seen people use that for the oil pressure, so I know it works...cant imagine why it's not working for you...
10-15-2019, 08:19 PM | #5 |
Any lifter noise?? I would pull the pan before you damage your motor
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
10-15-2019, 09:42 PM | #6 |
Doesn’t seem to be any noise. Pulled the pan today will put in a new pick up o ring and see where it takes me. Had a green o ring in it.
10-15-2019, 10:04 PM | #7 |
Any metal flakes in the pan?
10-16-2019, 12:08 AM | #8 |
Has the engine been opened up since it was last ran? I've read about(no first-hand experience) two things that could kill the oil pressure. There's a small oil gallery block-off plug inside the front cover. If missing, there will be absolutely no oil pressure. There's also something called a "barbell" in the back of the block. If missing, the pressure is supposedly very low.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
10-16-2019, 10:49 AM | #9 |
Pan is “clean” didn’t see any metal shavings or flakes. Think the only thing that has been off is the pan to swap to a pan that will clear the crossmember. I didn’t do the framework or install the engine but looks like the only thing changed was pan and pickup tube. I have a new pickup tube o ring and pan gasket on order. The thing that struck me as odd was the small gasket that is on the back left side of the oil pan with the 2 holes in it was not there. That do it? Cause zero pressure? Just crazy cause it’s filling the filter so it’s pumping something just both the pass where I put the oil pressure sending unit.
10-16-2019, 10:55 AM | #10 |
this one
10-16-2019, 03:19 PM | #11 |
that would def cause issues, wonder what gasket you got...
10-16-2019, 03:37 PM | #12 |
I ordered a new one that has this. Looking at the flow diagram of the oil in that engine should take care of it.
10-23-2019, 05:48 PM | #13 |
That goes into the oil filter so if gasket wasnt there then the oil pressure will blow back into the pan
10-30-2019, 10:56 PM | #14 |
Definitely fixed my issue thanks all
10-30-2019, 11:50 PM | #15 |
What fixed your issue?
11-01-2019, 01:04 PM | #16 |
I believe a new pan gasket with the two-hole gasket included fixed the issue for OP
Like so |
11-02-2019, 09:40 PM | #17 |
Yes replacing the gasket fixed it!!
