04-26-2018, 12:15 AM | #1 |
Transmission gaskets
I am in the process of putting my 3 speed saginaw back together. There is a paper gasket that goes between the main housing and the tail shaft. Normally I would use some sort of sealer, but the factory manual says to hold it in place with some grease. Never heard of that before. What does the collective suggest? Thanks.
04-26-2018, 02:32 AM | #2 |
Re: Transmission gaskets
I use high tack sealant for assembly of most gaskets.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
04-26-2018, 06:58 AM | #3 |
I used grease for many years always worked fine. Were not much of any of the rtv sealers when I got started working of stuff. Grease was just what you used.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-26-2018, 07:23 AM | #4 |
I use copper coat spray . It will hold in place as well as enhance sealing . This is what autogear suggest .
04-26-2018, 10:36 AM | #5 | ||
"I ain't nobody, dork."
All paper or cork gaskets get a light coat of Gasgacinch for me.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-26-2018, 11:28 AM | #6 |
^^This^^ for the thin paper gaskets.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
04-26-2018, 01:30 PM | #7 |
What about coated gaskets? anything used on them?
1961 chevy K10 my build is------------61K10 build |
