Old 12-15-2010, 10:29 AM   #1
Prerunner1982
Prerunner1982's Avatar
Freeze plug removal
What is the easiest way to remove a freeze plug? It is rusted and leaking and will be replaced with the engine still in the vehicle. I have never replaced one....it is on an early 90s GM V8 in a fullsize van...
Thank you.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-15-2010, 10:46 AM   #2
geezer#99
geezer#99's Avatar
Re: Freeze plug removal
There is no easy way. Use a big screwdriver to punch a hole in it and pry it out. Might need some needle nose pliers or channel locks to grip it with. And there's always more coolant in there too no matter how well you think it's drained.
While you have it out why not put a block heater back in. Easier to put it in than try to put a freeze plug back in. The plug's fun to install even when the motor is on an engine stand.
Old 12-15-2010, 10:57 AM   #3
Prerunner1982
Thanks Geezer.... this is not my vehicle so it is not really up to me as far as the block heater goes. When a freeze plug is only $0.99-$1.99 the owner doesn't want (or need) to spend more money than necessary on this. Also we really don't need them around here.
Jon
Oklahoma Roll Call
Old 12-15-2010, 11:26 AM   #4
MrDude_1
use a large self tapping screw (bolt).. screw it into the plug, then, pry on it until it bends the sheetmetal plug and comes out.
this is easier in the car then hitting/prying it with a screwdriver, because you can pry from the sides...
outside the car, just punch a large screwdriver off center into it and pry it out.
MrDude_1 is offline   Reply With Quote
Old 12-15-2010, 11:33 AM   #5
allengator
allengator's Avatar
I always place a punch or 3/8 extension on one side and tap with a hammer... this will cause the plug to rotate outward on the opposite side.
Then pull out with a pair of channel locks.
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 12-15-2010, 12:46 PM   #6
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
If you have room the self tapping with a slide hammer is slick.
To reinstall them can almost be as much fun.
Use a socket and extention the same ID as the edge of the cup - so you are just inside the lip - any smaller and you can crush the plug
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 12-15-2010, 01:06 PM   #7
Ticker
This is how I do it - but it's always a PITA
I'll have to try some of the other approaches here; they look interesting
Learn something new every day...
Ticker is offline   Reply With Quote
Old 12-15-2010, 02:07 PM   #8
stich626
sad part is, if one went, the rest are soon to follow.
as far as redneck,backwoods,cheap.. jb weld..
stich626 is offline   Reply With Quote
Old 12-15-2010, 05:25 PM   #9
Prerunner1982
Thanks again guys....
Jon
Oklahoma Roll Call
Old 12-16-2010, 10:22 AM   #10
Prerunner1982
Father in law found a rubber plug made to go in there and he was able to get it replaced last night. He said the old plug was pretty weak and came our fairly easy..
Jon
Oklahoma Roll Call
Old 12-16-2010, 11:04 AM   #11
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Bam....this is the way. I was amazed at how easy it is. The trick is to get the correct size channel locks that will allow you to leverage on the block and pry them out. At least on BBC I even knocked a few into the block and it was really easy to fish them back out. They don't go far and you can still get the locks on them and rotate them out. I would not waste your time trying any other way!!!
prostreetC-10 is offline   Reply With Quote
Old 12-17-2010, 12:22 AM   #12
Captainfab
60-66 Nut
I replaced all the external freeze plugs on a 454 in my late Father-inlaw's '79 C10, many years ago. Never again. I did them all with the same reasoning. If one is bad, the rest aren't far behind. Getting them out was the easy part. Trying to drive in the new ones was next to impossible......there's just not enough room to swing a BFH. IMO you would be better off to just pull the engine and change them on a engine stand. The time may be the same, but with much less agrivation.
