Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 02-19-2017, 07:22 PM   #276
keniniowa
Re: Show lowered 88-98 trucks
Originally Posted by gearheads78 View Post
My 96 I sold about 13-14 years ago. Look small for today but my 18" Billet Specialties wheels where the **** back then LOL
What's the drop on that? I'm looking at a twin to it and that's about the stance I'd like to end up with.
keniniowa is offline   Reply With Quote
Old 03-05-2017, 02:33 PM   #277
laidbackbigun
My 1992 C1500, bagged on 20 inch Ridler 695's. Lays currently crushing the exhaust y pipe. Soon to be remided and it will lay flat.
laidbackbigun is offline   Reply With Quote
Old 03-15-2017, 02:44 PM   #278
88lowrider
Nothing fancy about mine other than she is a 1988, got her in 1990 and slammed it.
Nothing special. Don't have the tonne cover on right now.
88lowrider is offline   Reply With Quote
Old 03-15-2017, 06:19 PM   #279
What is the specs on your lowering? 4/6??
1981 GMC High Sierra SWB Stepside
"Whitey" 2002 Chevy Silverado 1500 SWB W/T
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 03-15-2017, 07:18 PM   #280
88lowrider
This came down 6" by a outfit that used to be in Gresham Oregon called Charley's Drop Shop.
They modified the lower A frames and not sure what was done in the back other than they had to notch the frame too.
This allowed better control of adjusting the caster and camber. She does not eat tires like the drop spindle lowered trucks. That I like !
The cross frame under the motor, 3" clearance. If the tire comes off the rim, she is on the asphalt.
Old 03-15-2017, 07:28 PM   #281
Thanks for the info. It has a really good stance
Board Vendors
Old 03-15-2017, 07:37 PM   #282
88lowrider
Thanks Bill.
I ended up using some Monte Carlo shocks in the front and not sure in the rear which were air shocks.
I never did pull the rear springs as the overload spring needs to be changed.
We have a place up in Portland Oregon called Oregon Spring. I give them what measurements I have and they re-arch the overload spring.
I started out and was going to put a Air Lift (bag in a coil spring) setup in the rear but never did. I really need too as if your going pack anything around, she will come down and pumpkin will hit the bottom of the truck bed. Done that a few times ;-/
I remember being a little on the tipsy side heading back home from a friends house and forgot the 30mph curve. I hit it about 70mph and Everything in the cab was up against the door and window, including me. She went around that corner like she was on rails.
The front shocks were some trick gas shocks. I can't find the book on her since the move and in that book, I wrote down what shocks I used. Hope to find it but even if not, they can take those off and match them up.
She still rides like a car too.
Helmar
Old 04-15-2017, 03:29 AM   #283
<AMP>
<AMP>'s Avatar
my 92 2/4 drop
<AMP> is offline   Reply With Quote
Old 05-04-2017, 05:59 AM   #284
Joseog83
Joseog83's Avatar
Update: got the AR torque thrust wheels on it along with the Nfamus control arms also got rid of the hideous exhaust tips, a few more changes and it'll be ready
Joseog83 is offline   Reply With Quote
Old 05-04-2017, 04:39 PM   #285
laidbackbigun
Thats one sexy truck. what did you do about the exhaust, i'm crushing my y pipe currently.
Old 05-05-2017, 09:55 PM   #286
91short
Love your truck.
91short is offline   Reply With Quote
Old 05-05-2017, 10:41 PM   #287
UKNOWME
UKNOWME's Avatar
Why did you take off the billets?
Do you know the backspace on the TT wheels?
Are you running staggered?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
1961 Chevy Apache 30
1988 Chevy c20
UKNOWME is offline   Reply With Quote
Old 05-06-2017, 01:34 PM   #288
likaroc13
Rollin' Old Skool
Looks good!
Good question; I liked those billets!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 05-06-2017, 01:45 PM   #289
likaroc13
Rollin' Old Skool
On my old '93 with 5/8 drop, I had an exhaust shop make a new one & tuck it up higher.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 06-04-2017, 12:31 AM   #290
bigpetie
bigpetie's Avatar
Originally Posted by 62 bigwindow View Post
1994 c1500
Got it lowered and finally found a wheel and tires size I am happy with
details on wheel tire package ...btw CLEAN
94 EXTENDED CAB
64 CHEVELLE
bigpetie is offline   Reply With Quote
Old 06-06-2017, 12:40 PM   #291
busta9876
My 1997 C3500 with a 5.9L Cummins, work in progess
I've got a 1997 C3500 Dually with a belltech drop spindles. Anyone else had issues with brakes pulling one way or other? There is a large gap between top of brake caliper and the spindle on my truck, and belltech sent me a second spindle and it measures the same, and looks the same with new caliper installed. (large gap at top, only on drivers side) This is causing caliper to twist, wear brakes uneven, and pull to the left.
1997 C3500 5.9L Cummins Conversion
1989 Caprice Classic 5.3L Turbo 4L80E
1967 Chevy C10 6.6L Duramax Conversion In Progress
http://www.lt1swap.com
busta9876 is offline   Reply With Quote
Old 11-12-2017, 04:39 PM   #292
WillD7545
My 96' 4.3 pulling my 64' Datsun 320. Both trucks flooded last year. The battery was disconnected so the electrics seemed fine after I let it dry out a few weeks. Looking to pull the 4.3/4L60 and drop in an LS/trans once I get the house finished up.
WillD7545 is offline   Reply With Quote
Old 11-12-2017, 05:56 PM   #293
UKNOWME
UKNOWME's Avatar
Thatís awesome you have a Datsun! Iíve been wanting to do a 320 for a few years now.
1964 Chevy c10
1988 Chevy c20
Old 11-25-2017, 12:21 AM   #294
MotorHead Lon
MotorHead Lon's Avatar
Update on my 88. 17x8 and 17x9 Eagle wheels, with 255/60 and 275/60 17s. Black truck is my old 90, Dropped with spindles, and dropped springs. The springs had 1 coil cut. Ended up at a 6" drop. 6" steel wheels, forgot tire sizes.
88 Chevy C1500, step side, LS swap.
MotorHead Lon is offline   Reply With Quote
Old 11-25-2017, 09:20 AM   #295
Love the look & stance on your bule 88!
Board Vendors
Old 01-08-2018, 06:17 AM   #296
fredscarryall
fredscarryall's Avatar
My 1990 454 ss
fredscarryall is offline   Reply With Quote
Old 01-08-2018, 06:29 AM   #297
DZL1
One day.....
DZL1's Avatar
Originally Posted by fredscarryall View Post
My 1990 454 ss
WOW....Beautiful!
DZL1.
Bertha build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=733306
'72 C10 short bed. Bessie (traded)
'93 C3500 CC Dually. Bertha
DZL1 is offline   Reply With Quote
Old 01-15-2018, 01:58 PM   #298
SniperSteve
Re: My 1997 C3500 with a 5.9L Cummins, work in progess
Attachment 1658669
Attachment 1658665
Attachment 1658666
Attachment 1658667
Attachment 1658668
Hey bud. You might have a bent brake caliper bracket.
Had a problem like that with a montero sport.
SniperSteve is offline   Reply With Quote
Old 02-03-2018, 05:09 PM   #299
SniperSteve
Not mine. But it pops up everytime i look up pictures on google.
Anybody know the truck
Old 02-03-2018, 07:32 PM   #300
bigpetie
bigpetie's Avatar
what drop and tire size ? btw clean !!!!
94 EXTENDED CAB
64 CHEVELLE
Copyright ©2000 - 2018, vBulletin Solutions Inc.
