Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 03-16-2015, 08:09 PM   #1
IIRoccoII
o2 senor question
If i delete my cats how could i stop the check engine lights
IIRoccoII is offline   Reply With Quote
Old 03-17-2015, 03:37 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: o2 senor question
What year truck? Does it run on a computer chip or is it a tuneable computer setup?
Frank
Old 03-17-2015, 05:39 AM   #3
IIRoccoII
It's a 1993 TBI 350 engine
Old 03-17-2015, 12:42 PM   #4
iluvmy72
If it's stock it should only have 1 cat and 1 sensor. You might need to have a custom computer setup. If you are trying to improve gas mileage, you won't see any except a higher bill for the deleting.
iluvmy72 is offline   Reply With Quote
Old 03-17-2015, 01:47 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
You might have false oxygen sensor readings.
The cat will have a small amount of back pressure. That will keep some heat in the exhaust for proper oxygen sensor readings. If you remove the cat, it will let the exhaust escape faster, and the heat will not stay in the pipe long enough to keep the sensor at the correct temp.
You can correct all of that by using a heated oxygen sensor.
-99 K2500 LS CCSB 7.4
-96 C3500 HD 7.4 NV4500 Rollback
My 85 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=368864
78 Big10 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=383629
96 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=614515
95 S_Trucker is offline   Reply With Quote
Old 03-17-2015, 03:33 PM   #6
OutlawDrifter
+1 on a heated o2 sensor.
2013 Ford F150 FX2 CCSB 5.0L
1991 Z/28, 6.0L/T56
Old 03-17-2015, 03:44 PM   #7
iluvmy72
have you had it scanned yet for the code? if I remember right you can take a paper clip to do this at home. But its been a while.
Old 03-19-2015, 04:41 AM   #8
likaroc13
Rollin' Old Skool
On my old '93 C1500 with 350 TBI, I had the cat deleted. It never showed a check engine light. I know I personally didn't do anything to remove codes, & I don't recall the shop that did the cat-delete doing anything either. Made it a little louder, but it didn't hurt performance or gas mileage at all in my case.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 03-19-2015, 03:31 PM   #9
speedygonzales
speedygonzales's Avatar
There is none
After Cat O2 sensors did not come along till 1996 with the advent of OBDII.
So hack away.
If anyone wants to know you get rear O2 simulators that connect in parallel to the O2 sensors to make the ECM think they are working. I used them for years until I had them programmed out.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 12-06-2017, 03:52 AM   #10
Harley03joe
Harley03joe's Avatar
Well I Just Looked For A Heated 02 Sensor For My 87 Chevy R 10 Silverado
Ans Every Place I Looked It Said >>>This part is not compatible with 1987 Chevrolet R10 Silverado Standard Cab Pickup 2-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated.
Do You Have A Part # For Me To Look At ??
Thank You Harley03joe
1931 Ford Like New And For Sale
2004 Harley Davidson Heritage Classic
1987 Chevy R 10 Silverado
2007 Azera
2011 Cadillac CTS Premium
Harley03joe is offline   Reply With Quote
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
