Old 11-25-2017, 12:36 PM   #1
7echo
head light wiring
I am going to up the wire size and install relays to get more volts to the head lamps.
Where and how should I tap the high and low beam wires?
I saw some of the harness makers had a plug or 2 to attach to the existing harness. I can not find those local so I may look for one in the pick and pull. Or maybe I should just cut, solder, and heat shrink?
1993 Silverado, 305, auto, short bed
7echo is offline   Reply With Quote
Old 11-25-2017, 03:03 PM   #2
b454rat
Re: head light wiring
I would just cut spice n solder. I had the kit, was nice, but had a stupid diode and if it burns out then no lights.
Old 12-02-2017, 11:09 PM   #3
no2tracks
try this? http://www.lmctruck.com/icatalog/cd/full.aspx?Page=64
'94 K2500 Silverado 7.4 auto 4x4
no2tracks is offline   Reply With Quote
Old 12-03-2017, 10:37 PM   #4
7echo
Originally Posted by no2tracks View Post
That one is for the single headlight trucks. Mine is 2 lamps in the composite style. 9006 and 9005 lamps.
Old 12-04-2017, 10:15 AM   #5
Kudzupatch
Kudzupatch's Avatar
What voltage are you getting to the headlights now?
Kudzupatch is offline   Reply With Quote
Old 12-04-2017, 11:04 PM   #6
no2tracks
Sorry I didn't do a comprehensive search for you. I did get you to a place where they do have the proper kit if you looked;
http://www.lmctruck.com/icatalog/cd/full.aspx?Page=68
I believe you'll want option C.
So related to this thread, I'm wanting to install Halogen bulbs in my composite housings, will I need to upgrade the wiring like 7echo?
Old 12-10-2017, 09:45 AM   #7
7echo
You know, I have not checked and should. I do know that they seem too dim. From reading it seems like a lot of guys have this complaint so I was just going to do the relay and larger gauge wire.
Old 12-10-2017, 09:53 AM   #8
7echo
My fault!
I did look. But, I looked at the image and saw the wrong connectors and moved on. If I had READ the actual description I would have seen they had the correct one for my truck.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
