Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-23-2017, 10:00 PM   #26
pwdcougar
pwdcougar's Avatar
Re: Air compressor: rebuild or replace pump?
Dredging up an old post. I'm finally getting around to installing the Schulz MSL 10 Max pump I got in the fall. The online pulley calculator I found says that my 3450rpm motor with a 4.25" pulley will spin the 10" pulley on the Schulz pump 1466rpm. The Schulz website says my pump should spin at 860rpm. Will the 606rpm increase be too much for it?
If I can install the old pumps 14" pulley it brings the rpm down to 187 over the recommended pump speed.
On the other hand if I find a 2.5" motor pulley it puts me almost spot on Schulz's 860rpm
Am I missing anything here?
Paul
Schulz site: http://www.schulzamerica.com/product...e/max-140-psi/
Calculator site: http://www.blocklayer.com/pulley-belteng.aspx
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-24-2017, 06:22 PM   #27
Dead Parrot
Spinning the pump too fast will increase the heat generated in the head and create additional load on the motor. Not an expert but would be best if you can swap the 14" pulley to the new pump AND buy a new motor pulley of the correct size to get the recommended RPM. Too small a motor pulley might not leave enough contact area to drive the belt.
Dead Parrot is offline   Reply With Quote
Old 02-24-2017, 08:31 PM   #28
pwdcougar
pwdcougar's Avatar
Thanks Parrot. I found this information on one of the Ebay sellers pages. It says to spin it between 700 and 1000.
Paul
Old 02-24-2017, 11:24 PM   #29
68c10airstream
68c10airstream's Avatar
Typical motor rpm's are usually around 3600 or 1800. Dead parrot is spot on about spinning at 1,000 rpm's or less.
68c10airstream is offline   Reply With Quote
Old 02-25-2017, 01:29 AM   #30
pwdcougar
pwdcougar's Avatar
Thanks guys. My motor data plate says it spins at 3450rpm. My old pump pulley and the new pump have different shaft sizes so that swap is out. Using a 2.5"pulley on my motor will spin the new pump at 902rpm.
Paul
Old 02-25-2017, 11:41 AM   #31
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Paul
Mc Master Carr is up your way and may have the pulley(s) you need.
https://www.mcmaster.com/#pulleys/=16ibzs2
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 02-26-2017, 04:58 PM   #32
pwdcougar
pwdcougar's Avatar
Originally Posted by richard2717 View Post
Paul
Richard
That's a great website Richard! Very well laid out. Found the pulley that would work in secods. Unfortunatley I spent an hour on ebay and ordered one about an hour earlier than I saw your reply!
Paul
