Old 06-01-2018, 10:45 PM   #1
1968C10LWB
1968 C10 headlights flash with engine on or off
I have read the previous post regarding this same issue and have checked the grounds and replaced the dimmer switch. There are no sounds when the lights start flashing and it will happen with the engine on or off. i just picked up this truck about 6 weeks ago so I don't know the history of what has been done.
Any ideas to help me troubleshoot?
1968C10LWB is offline   Reply With Quote
Old 06-01-2018, 11:14 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: 1968 C10 headlights flash with engine on or off
Welcome aboard!
Is it just a random on-off-on-off, with no regular pattern? Does it happen only when the light switch is on? Without more info, I'd guess a bad headlight switch. You might have to remove the switch to access it to test it with a test light or basic VOM. It might also be a loose-fitting connector on the headlight switch.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-02-2018, 12:15 AM   #3
1968C10LWB
It is when the switch is on. I haven't checked the headlight switch itself. Good call, I will let you know
Old 06-02-2018, 05:48 AM   #4
Grumpy old man
Grumpy old man's Avatar
Fords were famous for this problem in the 70's , Stockers right head towards the light.... (switch)
Old 06-02-2018, 08:19 AM   #5
phat69
unplug the switch and see if it stops.
phat69 is offline   Reply With Quote
Old 06-14-2018, 12:51 AM   #6
1968C10LWB
It was the switch...thanks for the help!
David
Old 06-14-2018, 12:59 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Glad you found it, and thanks for the follow-up!
- Mike -
RIP El Jay
