Old 12-02-2017, 08:57 PM   #1
emil77
Leaking Fuel Pump - Easy to replace?
The fuel pump on my 72 C20 is leaking, 5.7 V-8. Is this an easy thing to change or am I going to get in over my head? Will gas leak all over me when I change it? Any tips/tricks/comments?
Thanks,
Emil
1972 Chevy C20
emil77 is offline   Reply With Quote
Old 12-02-2017, 09:32 PM   #2
rob32472
Re: Leaking Fuel Pump - Easy to replace?
Easy to change. Lots of Vids on you tube. You will most likely get some fuel on your hands, but nothing major.
rob32472 is offline   Reply With Quote
Old 12-02-2017, 09:33 PM   #3
emil77
I bought the 3 line fuel pump for a 5.7 350 V-8, that's correct?
Thanks,
Emil
1972 Chevy C20
Old 12-02-2017, 10:34 PM   #4
toolboxchev
For a 72? Or California truck? Mine is just a 2, in and out. Mine is a 70. Just crimp the fuel line coming out of the cab with a pair of vise grips. Should stop the flow. Make sure you get the gasket in, and the pushrod goes back in the way it came out.
toolboxchev is offline   Reply With Quote
Old 12-02-2017, 10:56 PM   #5
Pro299
Junior Member
Sometimes the pushrod will try to fall out. Some guys use a dab of grease to hold it for the few seconds it takes to get the pump in place. If that doesn't work, most blocks have a tapped hole on the front you can run a bolt into that will hold the rod in place while you get the pump tightened in. Just don't forget to remove that bolt afterward.
Pro299 is offline   Reply With Quote
Old 12-03-2017, 12:29 AM   #6
RichardJ
Be sure and check the engine oil for over filled from fuel entering crankcase. Check to see how the oil smells.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 12-03-2017, 12:43 AM   #7
In The Ten Ring
Is your original fuel pump mechanical?
Mine was mechanical and it was a breeze. I removed it, cleaned the old gasket area with sandpaper, cleaned that residue off, and used a Carter replacement (mechanical) pump with new gasket.
I tightened the bolts back in a little bit on each one to get the thing to seat all over instead of tightening down one bolt and then the other.
I watched videos on the process but didn't need to glue the thing down at all. I think mechanical pumps are the way to go.
In The Ten Ring is offline   Reply With Quote
Old 12-03-2017, 02:55 AM   #8
70LonghornCST
Moderator
70LonghornCST's Avatar
Changing a fuel pump will raise your confidence level as a mechanic, that's for sure. Very easy to replace.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 12-03-2017, 02:59 AM   #9
emil77
Thanks for the info y'all, I'll be doing it Monday with the help of a mechanic friend.
Thanks,
Emil
1972 Chevy C20
Old 12-03-2017, 03:00 AM   #10
emil77
I guess it's a California truck, I have 3 connection pump.
Thanks,
Emil
1972 Chevy C20
Old 12-03-2017, 05:46 AM   #11
In The Ten Ring
I guess California has been more complicated for a long time then.
So you don't just have a mechanical pump on the side of our engine like my 250 does? *Mine is at 9 O'Clock in the pic, the brass-looking round thing.
Old 12-06-2017, 02:52 PM   #12
emil77
I swapped it out Monday night, pretty cool experience! I now know what it feels like to have gas drain on you, haha!
Thanks,
Emil
1972 Chevy C20
Old 12-06-2017, 02:55 PM   #13
emil77
Not sure, mine had 3 lines. One is fuel return, one from gas tank and one is that line that comes up into the engine, carb I think?
Thanks,
Emil
1972 Chevy C20
Old 12-06-2017, 05:51 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yeah, but yours is upside down!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 12-06-2017, 06:00 PM   #15
In The Ten Ring
I went to all the trouble of reaching over my grill and down into the engine bay to change out mine only later to remove the entire front end.........
