01-13-2010, 07:17 PM | #1 |
Too many toys,not enough money
Which is the correct way to install dist. center plate?
It's a chevy 350 HEI distributor.
Which is the correct way to install the dist. center plate? I have two of these distributors and the both came apart different. The top set is out of a Mallory dist. in the picture the center plate has rounded edges on the bottom and a "L" stamped into the top. The bottom set is GM, all numbers are up. |
01-13-2010, 07:37 PM | #2 |
Redefining LowBudget
Re: Which is the correct way to install dist. center plate?
bottom right
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
01-13-2010, 08:00 PM | #3 |
Active Member
As hottrucks said...
scroll down for good pictures. http://www.rustpuppy.org/ignition2/Ignition%202b.htm |
01-14-2010, 01:08 PM | #4 |
Thanks guys, I thought the bottom right was right, but I started overthinking things and confused the heck out of myself.
01-14-2010, 03:50 PM | #5 |
