09-23-2018, 07:10 PM | #1 |
A/C Part Identification
The air filter rubbed through this A/C line on my 1990 Suburban. What's the name of this part and where would I buy another one?
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
09-23-2018, 10:19 PM | #2 |
Re: A/C Part Identification
High side line from the condenser to the evaporator,with the expansion tube.
Looks like you have front and rear air,so be sure to tell them when you order the part. Mike. |
09-24-2018, 10:33 AM | #3 |
It's a very difficult part to find so I'm going to try JB Welding it.
09-24-2018, 10:41 AM | #4 |
J.B. Weld won't work at all!
Try to find a used one or have your local a/c shop build you one. Mike. |
09-24-2018, 10:51 AM | #5 |
Rock auto has that part.its in with the ac hoses.
09-24-2018, 09:54 PM | #6 |
Get a new Air Filter while you're on RockAuto!
10-02-2018, 12:05 AM | #7 |
find someone who welds aluminum and they can fix it for you. had to do that on my brothers ac hose before.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
