05-05-2015, 03:44 PM | #26 |
Re: Tie rod ends rub against tire with Dropped axle
Can i heat the steering arms using a propane torch? I don't have access to oxy-acetylene
05-05-2015, 04:39 PM | #27 |
Won't be able to get it red hot over a large enough area even if using MAPP.
05-05-2015, 04:45 PM | #28 |
i was afraid someone would say that. I want to get this done tonight.. only other option would be to slice the arm part way through, bend it and then re-weld.. but i'm not a great welder. and this is steering components here!
05-05-2015, 05:28 PM | #29 |
That wouldn't be acceptable if you aren't a few steps above a first class welder.
Remember, anytime you get in a big honking rush you end up screwing something up. I'd take a bit of time but you could pull the hubs, unbolt the steering arms and take them off and take them to someone who has a torch that can heat and bend them in a vise. After you bend them you will have to reset the toe in as bending the arms in will increase the toe in.
05-05-2015, 05:37 PM | #30 |
I couldn't' agree more. I have them off now anyhow, so i'll try and get someone to bend them in the morning as i need the truck in the afternoon.
I need to get my own o/a setup i think. |
05-05-2015, 05:44 PM | #31 |
I don't use mine as much as I used to but they sure are handy when you need them.
05-06-2015, 06:58 AM | #32 |
I'm happy to report that i was able to find a used set last night and the tanks were full. I have a friend coming over this morning to teach me how to user it. I'll get this done safely this morning, no rushing...
