06-03-2019, 11:36 AM | #1 |
Need a Photo np205
I am in the process of swapping my th350 to a th400 in my 71 k20 and I am looking for pics of the NP205 shifter location in the high hump floor (keeping engine in factory location) The th400 moves it back 3" and not sure of clearance......thx !!
1967 C10 SWB Owner - Rustbelt Restorations |
06-05-2019, 10:50 PM | #2 |
Re: Need a Photo np205
Have you considered moving the engine forward instead. Much less work and usually the holes are in the frame already. If not the t-case handle has to be bent to clear into the stock hole. I’ve seen it done with a 4l80.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
06-06-2019, 08:53 AM | #3 |
Was an abandoned project by others, trans crossmember and tc mount have been moved back and driveshifts have been built, was hoping to use what I have........also running a 292 and cannot move engine forward...prob just mod shifter but was looking for ideas......
06-06-2019, 05:16 PM | #4 |
i would make a new bracket / mount for the sifter handle and then a pair of hiem ends and threaded rod for a new link and be done with it .
this is a bit crazy but here is my custom mount for 5 levers . i built it off the top 4 bolts for the round 6 pattern adapter to the 203 range box on the 4l80-e to 241 adapter i used for the doubler . its just plate and 2 shifter kits from offroad design i modifyed . #1 - pto pump in/out for hydro winch #2 - in cab winch control #3 - 203 range box H/N/L #4 - rear output of 205 control H/N/L #5 - front output of 205 control H/N/L #6 lokar auto trans lever with linkage kit to make it work all the way up were its mounted back to the link point and then down to the trans arm .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. Last edited by sweetk30; 06-06-2019 at 05:24 PM. |
06-06-2019, 05:27 PM | #5 |
then when its ready for install i have the floor hump all layed out for the 3 boots . also will be using a stock sm465 shifter boot on the lokar shifter . and with its black shaft it will look like a 4 speed trans shifter .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
06-08-2019, 03:53 PM | #6 |
Post Whore
Too cool!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-08-2019, 04:09 PM | #7 |
ya anti-theft kit for gear heads . 6 levers who the heck will figure it all out even with a sticker showing the combo .
