Old 10-21-2018, 05:08 PM   #1
sluggy
Stopping After the swap
I have an ls3/6l80 combo in my 62 C20. Currently i have discs up font and drums in the rear.
Because I still have the original 62 front suspension, I have used Early classics C20 to C10 conversion spindles, and their disc kit on the front end. Running a vacuum assist master cylinder. I changed the rear end to a 12 bolt and am just running the stock drums on the rear.
I have had a couple of close calls where she just keeps rolling !! So I feel like I need better anchors.
Id be interested to hear what others are using ?
sluggy is offline   Reply With Quote
Old 10-22-2018, 10:41 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Stopping After the swap
The set up you have should be pretty decent, but if it's not working right, are you sure its fully bled? If so, what size of vacuum booster are you running? I had a 7" dual diaphragm booster on my car that everybody said was the thing to use and it was terrible. I switched to a Hydroboost and its way better. Might be something to consider, although I don't know how hard they are to come by in New Zealand.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-22-2018, 11:02 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm running a hydroboost setup with Wilwood's up front, and am in the process of converting my 12bolt to run D52's out back via Captain Fab's setup.
Even on disc/drum my truck stops pretty damn flat in a hurry, plenty to lock em up if needed.
I did randomly find out this weekend that my truck had a Wilwood 2lb anti-drainback valve in the front lines...never knew that before. Supposedly it helps with calipers that draw-back too far when the master is mounted low. Not sure if its helping me, but I'm keeping it in.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-23-2018, 10:17 AM   #4
truckdude239
truckdude239's Avatar
Im rocking the stock non power brakes on my 71 disc /drum and it stops just fine something isnt right with your set up
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-23-2018, 12:08 PM   #5
Custom 68
Custom 68's Avatar
Brew, which master cylinder did you go with on your setup. I am using one from a hydro boost tahoe and think it is too large of diameter. I am looking to swap down a size. I believe mine is 1.25 diameter bore. I think I need a 1.125
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-23-2018, 01:23 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm using the master that came off the hydroboost donor. ~96 astro
Old 10-23-2018, 03:34 PM   #7
sluggy
Pedal feels solid, but i will give it another bleed anyway, booster is a 9" single diaphragm. There is no way I can get this to lock up though. I am running 20" detroit steel wheels, these things are heavy - approaching 55lbs per rim plus the tyre, Im pretty sure that doesnt help much. Ive got some 15" rims that i will try on it to see if that makes muh difference.
Old 10-23-2018, 03:50 PM   #8
verdell
verdell's Avatar
I have CPP dropped spindles, '75 1/2 ton mc, dual diaphragm booster and a 65 12 bolt drum rear with no issues. Are you certain your torque converter is unlocking?
verdell is offline   Reply With Quote
Old 10-23-2018, 03:54 PM   #9
Custom 68
Custom 68's Avatar
Thanks I may give one a try.
Dave
Dave
Old 10-23-2018, 05:23 PM   #10
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Dave, I have one off an astro you can have. It is missing a cap off the big reservoir.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-24-2018, 10:29 AM   #11
Custom 68
Custom 68's Avatar
Thanks Shannon, we do need to get together.
Dave
Dave
Old 10-27-2018, 12:37 AM   #12
sluggy
I think that is the issue. It feels like its driving through the brakes. I'll check the wiring to the trans and make sure I have it right.
Thanks for the suggestion !!
Old 10-27-2018, 12:46 AM   #13
72MARIO
72MARIO's Avatar
I am interested how much of.a diffirence the 15" rims make in stopping. I have been looking at the Detroit wheels but the weight was my concern..
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-27-2018, 10:34 PM   #14
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I’m still running 15” wheels. Will Wilwoods fit or do you have larger diameter wheels?
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-28-2018, 11:52 AM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
That really depends on the wheel. My M/T front wheels clear them, and my Holeshot rears clear them, but my older Diamond's would be uncomfortably close.
Old 10-29-2018, 10:32 AM   #16
Custom 68
Custom 68's Avatar
I have the Wilwoods D52 replacement on the front and they will not clear my old 15 inch aluminum wheels. It is close but there is a slight rubbing.
I have converted to an aftermarket spindle so that may have a little affect?
Dave
Old 12-18-2018, 11:03 PM   #17
bigmoe
bigmoe's Avatar
Sluggy did you solve your braking problem? Would you be able to throw it into neutral and brake, to rule out the torque converter?
bigmoe is offline   Reply With Quote
