Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-08-2014, 05:42 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question Wiring heated seats
I bought a set of 1999 Chevy Tahoe bucket seats for the 71. They are electric with heaters. I need to know how to wire the heaters. I figured the electrical seat wires out but don't know about the heaters. The orange and black wires do all the electric seat movement on both seats that have the blue tape around them. I know the yellow is for the air bags.
Anybody have a diagram?
V Vette where are you buddy?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-09-2014, 11:10 AM   #2
Custom 68
Custom 68's Avatar
Re: Wiring heated seats
Subed
I have a set of new seats I will also be installing. I will assume we will need a special switch as my Tahoe heated seats have 3 temp settings plus a back only again with 3 settings. The seats I have don't have these controllers built in so I will need to add them.
Did you get all the movements working? I know some of these have memory and didnt know if that was an issue. I wont hook that part up but figure it needs to be bypassed.
mine are out of a 2005 Cadillac CTS.
So Andy you are doing away with your bench. Good luck.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-09-2014, 11:13 AM   #3
Custom 68
Custom 68's Avatar
just saw your other post and it looks like yours is all built in. Mine is gonna be kind of tougher I am afraid. I will need to do some digging I think.
Good luck.
Dave
Old 10-09-2014, 04:12 PM   #4
Andy4639
Old member
Andy4639's Avatar
Cool Re: Wiring heated seats
Thanks, same to you.
I looked at a set of seats with the switches on the door panels. I didn't want to spend all day getting them out and taking the door a part and chasing the wiring. I found these and the drivers side was already loose in the Tahoe. I think my buddies (electrians) here at work have me set to have heat tonight if we looked at the wiring correctly. I have found some aftermarket kits I will use if mine want work though.
All the seat movements work and the lumbar worked as well. I had to take the drivers side a part and straighten the rack out. I greased everything up good also. I will let you know later tonight are tomorrow if I get mine working.
http://67-72chevytrucks.com/vboard/s...d.php?t=645806
Check this thread also.
http://67-72chevytrucks.com/vboard/s...d.php?t=370574
Old 10-10-2014, 07:24 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Wiring heated seats
I have heat!
Old 10-10-2014, 08:35 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: Wiring heated seats
Well I tried but the heater just want work for me so! I'll start looking for a nice aftermarket set. Here is what is under neather the leather. I fixed several breaks in the heater wires. Every piece of black tape was at a break in the wiring.
I'll go back to the LQ yard Monday morning and pull as many modules as I can and get a few more small parts I wanted.
Old 10-10-2014, 09:18 PM   #7
gmachinz
I think my next project is gonna be a 4WD CC so I'm really thinking about adding leather heated seats....that would be killer....I'm following your thread my friend!
gmachinz is offline   Reply With Quote
Old 10-11-2014, 07:11 AM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Wiring heated seats
Depending on the seat you choose for your truck you will have to do some wiring to make them work. Mine where easy since everything is under the seat nothing else to buy.
Old 10-11-2014, 08:39 AM   #9
gmachinz
Yeah....my DD is a 2006 Yukon Denali and I thought it'd be cool to use the 2nd row heated bucketsbas the back seats for the CC.
Old 10-11-2014, 08:24 PM   #10
Andy4639
Old member
Andy4639's Avatar
I got the mirror working too! It's for sell. $40.00 + shipping. I have this already in my 71.
Compass & temp.
Old 10-12-2014, 09:07 AM   #11
Andy4639
Old member
Andy4639's Avatar
Mirror is sold. I may get another one tomorrow if I can find all the parts.
Old 11-19-2014, 09:05 AM   #12
Andy4639
Old member
Andy4639's Avatar
I got the drivers side in last night and wired up. Everything is working with just one minor problem.
I had plan to have the heated seats ground through the seat belt buckle so that if someone left the heater switch on it would automaticly shut off once the seat belt was unbuckled. Well it works backwards I guess it's for a buzzer instead, does anyone have any idea on how I can correct this? Info welcomed.
Old 11-19-2014, 12:45 PM   #13
67 Burb
67 Burb's Avatar
I would power the seat heaters through a relay. Activate the relay to be on only with the ignition on. (Not the ACCESSORY circuit)
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 11-19-2014, 07:50 PM   #14
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Wiring heated seats
This isn't the problem. That's how it is now.
I want the heater to cut off if the belt is unbuckled. This way if a passenger gets out of the truck and forgets to turn the switch off the heater will not stay on for no reason while I'm driving.
This is the only way I know for sure to have the heater turned off even if someone is in the passenger side and doesn't buckle up the heater want work.
Old 11-20-2014, 01:22 AM   #15
67 Burb
67 Burb's Avatar
Are you using the 99 Tahoe seat belts? If so, is the passenger seat belt wired to sense being done-up like the driver side belt does? If so, you could use that circuit to trigger a relay for the heater.
Bob
Old 11-20-2014, 03:10 AM   #16
Andy4639
Old member
Andy4639's Avatar
Yes, I'm using 99 Tahoe seat belts.
I think I have figured it out. The seat belt buckle per say doesn't have a switch in it. The buckle itself is the connector to the 2 wires inside the buckle. So if my thinking is right all I need to do is make the buckle the hot side instead of the ground. At least I hope so. I will try tomorow when I wake up and see if it works.
This way when the seat belt is un buckled the circuit is open with no power to the relay and once the key switch is turned off there is no power at all to it.
Old 11-20-2014, 03:44 PM   #17
Andy4639
Old member
Andy4639's Avatar
My thinking was wrong!
Old 11-20-2014, 09:38 PM   #18
Andy4639
Old member
Andy4639's Avatar
I think we figured it out tonight here at work.
A 5 blade NC relay. Terminals of relay 30, 85, 86, 87, 87a.
87A to seat heater,
30 & 85 will have 12 volts connected to them after the heater switch.
86 will go from relay to seat belt connection then to ground.
When switched on the relay wil power up but until the buckle is inserted nothing will happen because the belt is open to ground. Once the seat belt buckles the relay will open and current will flow from 30 to 87 and heat applied to seat.
Old 11-21-2014, 01:52 AM   #19
67 Burb
67 Burb's Avatar
87A to seat heater,
Andy, 87A is closed when the relay is at rest. With 12V to pin 30, current will flow to the seat heater when heat switch is turned on.
Then in the last line you say current will flow from 30 to 87. You don't have 87 connected to anything. Connect 87 to the heater.
(I always use 86 for the + and 85 for the - on the relay, so if I happen to have one with an internal diode, that's how they have to be wired.)
You will want something like this:
Bob
Old 11-22-2014, 01:36 AM   #20
Andy4639
Old member
Andy4639's Avatar
Here is what we came up with.
Old 11-22-2014, 12:13 PM   #21
67 Burb
67 Burb's Avatar
OK. Gotcha. I thought the seat buckle switch was the other way around.
Bob
Old 11-22-2014, 02:49 PM   #22
Andy4639
Old member
Andy4639's Avatar
It took two electricians and me to figure it out at work. We tried to use the relay in the heater seat kit but with the switch it just couldn't be done so I'm going to add another relay to the wiring to make it work like I want it to.
Drivers seat is wired with the relay above inline to turn on/off. It's temporarily until tomorrow when I'm off and can get it permanently finished.
Old 11-24-2014, 04:41 AM   #23
Andy4639
Old member
Andy4639's Avatar
OK both seats are installed and wired! Have heat on both sides. When the seat belt is unbuckled the heaters will shut off automatically! It took several people and me to figure it out but it now works as I wanted. All power and lumbar work as well.
I got the center console drying after using 2 part epoxy to fix where it had cracked. Once it dries good I will be doing filler and smoothing it out and cleaning the trim up to get it ready to install. My plan is to mount both amps inside the console. I hope they want over heat inside the console.
Old 11-29-2018, 01:19 PM   #24
Andy4639
Old member
Andy4639's Avatar
Almost 5 years and my seats are still working fine it was 24* here today and I was nice and toasty driving into work this morning.
Old 11-30-2018, 01:09 AM   #25
67 Burb
67 Burb's Avatar
Glad to hear that. I didn't know you got those kind of temperatures down in South Carolina. Of course 24°F would sound worse up here in Manitoba where that would be -4°C.
Bob
