11-23-2018, 10:57 PM | #1 |
Manual transmission
Hello, I have a 72 C10 longbed. I bought it with no motor or transmission. It originally came with a 350 and 3 on the tree. What transmission would that be?
11-23-2018, 11:54 PM | #2 |
Post Whore
Re: Manual transmission
what trans did it have in it?..most likely youll be looking at a sm465 4spd for it I assume...driveshaft mods are all part of it..but if you can find a lwb ds for a truck that came with whatever trans you choose,it should bolt in (maybe)
11-24-2018, 01:28 AM | #3 |
60-66 Nut
Having to have the driveshaft shortened is not that big of a deal. There are way too many variables involved in a engine and trans installation to be have any sort of a guarantee that a driveshaft from any other vehicle will be exactly perfect in your truck. Having a driveshaft shortened is not that expensive. Now having one lengthened which requires re-tubing, can get expensive.
11-24-2018, 01:38 AM | #4 |
Post Whore
i just had a 1pc ds completely built new from end2end..cost was way less than I expected..
11-24-2018, 08:40 AM | #5 |
It originally came with a 3 on the tree with a 350. I bought it without the motor and transmission. And the guy I bout it from took the shifter out of the 3 on the tree and put a hole in the floor for a manual transmission
11-24-2018, 04:32 PM | #6 |
Also. Would the original transmission be saginaw 3 speed? I'm new to this so bare with me.
11-28-2018, 12:35 PM | #7 | |
Pick the trans you WANT - don't limit to what you think will bolt-in with no mods. Mounting the pedal box and clutch linkage is more complicated than dropping off a driveshaft at a shop to have it shortened. You will be happier with the trans you want.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
11-29-2018, 04:07 PM | #8 |
I WANT the stock transmission back in it. I like keeping my truck somewhat stock and unchanged
11-30-2018, 12:36 PM | #9 |
Most likely a Muncie 330 was your stock transmission.
12-02-2018, 01:48 AM | #10 |
The original transmission for your truck is a Muncie M13. It was used in trucks behind 350s and 396s 69-72 and 350s 73-79. If you punch in " 3OTT question " in the forum search box you'll find a thread that shows a picture of the unit.
Steve weim55 Colorado Last edited by weim55; 12-03-2018 at 04:45 PM. |
