Old 05-17-2018, 03:23 AM   #1
Mr.Rogers
Mr.Rogers's Avatar
Need Input on Suspension Choices - QA1 or RideTech
Hello All! So I m in the final stages of making my mind up on a suspension setup but could use some input. I have a 1978 2wd LWB C10 that currently has 1/2 ton springs in front and 3/4 ton leafs out back with ride assist air bags. After purchasing the truck I immediately put dropped shackles on it to level the ride height. I am nearing the start of my ls swap and want to address the suspension and braking (which I already have figured out).
I am on the fence about installing the RideTech Street Grip kit for the truck. Or I am considering going with QA1's new tubular control arms for standard shocks and springs not the coil over setup as they still offer up to a 7 degree gain in caster. The RideTech Street Grip kit is a complete system. If I go with the QA1 control arms my thoughts are to add a QA1 sway bar, RideTech HQ shocks, RideTech lowering springs, and CPP modular spindle. I would also replace the leaf spring bushings with poly, remove 4 or 5 leaf springs from the pack and have the remaining leaf springs dearched.
I should mention that the truck is gaining an LS3 and 4l80e. Although there is plenty of power on tap I am not building a drag or an auto cross truck. Just building something I can hop in and simply drive the wheels off of, be super comfortable in, and that handles well. Also not looking to have a truck that is laid out. Any input/feedback you all may have is greatly appreciated.
Mr.Rogers is offline   Reply With Quote
Old 05-18-2018, 09:31 AM   #2
68Stepbed
68Stepbed's Avatar
Re: Need Input on Suspension Choices - QA1 or RideTech
I'd personally go with the RideTech setup. Do they offer the kit for leaf spring trucks?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-12-2018, 04:37 PM   #3
C10punk
I would go with the Qa1 if you are looking for great handling with less work and a bit cheeper. The Qa1 the main difference is that u don't have to change the crossmembers.
C10punk is offline   Reply With Quote
Old 06-15-2018, 12:56 PM   #4
cruizin01
I was real happy with the street grip kit on my build. I don't have it on the road yet but the height and quality and support was all very good.
'78 C10 Build
cruizin01 is offline   Reply With Quote
lwb, qa1, ridetech, streetgrip, suspension
