Old 09-20-2014, 03:18 PM   #1
C.R.
have one that wont start
1997 4.3 vortex won't start, getting fire to all plugs and getting gas. turns over, will start up then die. New fuel pump, wires, plugs, Cap and rotor button.
Floods out and gas going into oil. Any ideals?
C.R. is offline   Reply With Quote
Old 09-21-2014, 08:46 AM   #2
1990SSchevy65
1990SSchevy65's Avatar
Re: have one that wont start
Have you checked any of the sensors? Is the air filter clogged? Your tbi might be an issue. Good Luck, sorry I cannot be any more help.
2003 Chevrolet CCSB 4x4 1500HD Mine
2011 Toyota Corolla S Wife's new ride
2002 Pontiac Grand Am SE2 Wrecked/Totaled 2014
1990 Chevrolet 454SS GONE 02/26/11
1991 S10 SCSB GONE 12/24/08
1965 Chevrolet LB GONE 06/06/05
GM for life
1990SSchevy65 is offline   Reply With Quote
Old 09-21-2014, 01:55 PM   #3
C.R.
New air filter, it has the CPI and its is a rebuilt one. Thanks for the reply.
Old 09-21-2014, 02:02 PM   #4
dfrank
dfrank's Avatar
If gas is going into the oil then it sounds like your piston rings are shot.
dfrank is offline   Reply With Quote
Old 09-21-2014, 09:40 PM   #5
ChevyTech
To me it sounds like a cracked fuel line under the plenum, or a ruptured fuel pressure regulator diaphram.
I would put a fuel pressure gauge on it and see if the pressure drops as soon as the pump gets done with the 2 second prime.
A leak under the plenum will dump fuel right into the valley which will drain into the crankcase.
Old 09-22-2014, 02:11 PM   #6
C.R.
Thanks I will check it tonight and see.
Old 09-24-2014, 07:29 PM   #7
C.R.
Checked the pressure on the pump on 2 second prime it stayed on 0.
Cranked engine over and it went to 58psi. Removed the plenum and no evidence of gas on the intake. Checked it again after turning the engine over still dry.
Old 09-24-2014, 07:48 PM   #8
ChevyTech
Something is wrong!
If it did not build up any pressure during the fuel pump prime, then it it could be leaking all that fuel into the engine through the CPI unit.
Did you cycle the key and try running the pump a couple times in a row to see if it could build pressure?
Old 09-25-2014, 10:41 AM   #9
C.R.
Yes cycled it several times same results.
Old 09-25-2014, 09:16 PM   #10
ChevyTech
Pull the poppets out of the intake and set each one in a little cup leaving the CPI and supply lines intact, then cycle the key and see if fuel come out the poppets.
If fuel does come out the poppets, disconnect the wiring to the CPI and try it again. If fuel still leaks out the poppets, shop around for the upgrade unit that uses injectors instead of poppets, if your vehicle does not already have the upgrade.
If your vehicle already has the upgrade, let us know.
Old 09-27-2014, 08:45 PM   #11
hugger6933
Spyder valve!! I consider those a tune up item on the 4.3 [vortec ]HO motors they make a ton of difference in the way they run. I had a hard time talking some of my customers into them because of price until they HAD to have them but once installed the thanked me. Their gas mileage went up and performance was like when they first bought them from me or better. Open up the manifold, just the top half and look for puddles and clean spots you will find the gas leak in there really easy. Jim
hugger6933 is offline   Reply With Quote
Old 09-28-2014, 05:25 PM   #12
ChevyTech
Hugger, I agree.
It is hard to get people to do the upgrade, but once it is done they are very happy they did it.
C.R., I suggest having someone cycle the key for you as you watch the spider for leaks. It is very common for the regulator and supply lines to leak.
Old 10-18-2014, 10:36 AM   #13
C.R.
I got the fuel problem figured out. On the 2 second prime the pressure will go up to the 58 psi and you can here the poppets spray. then it will slowly leak down to about 30 psi.
