02-18-2019, 06:08 PM | #1 |
Suburban fuel sending unit
Any recommendations for a new fuel sending unit? Not sure I want to put the 50 year old one back in the tank before dropping the body back on the frame.
Thanks Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
02-20-2019, 11:15 PM | #2 |
Re: Suburban fuel sending unit
I took my old one out inspected it and reinstalled it. Not a lot of wear items on it. Plus I knew it to be accurate. If your tank is clean inside then most likely it hasn't been exposed to corrosion. If your concerned replace the float. It really isn't a big deal to drop the tank and replace it if you have to. It took me about 30 minutes to have the tank on the ground and another 30 to get it cleaned up and pull the sender. I pulled it out since the fuel supply tube to the engine was leaking and needed resoldered. The sock was fairly clean and a little compressed air took care of was there. I did a resistance check with a ohm meter and it was all nice and smooth. ( photo shows a digital meter but I also used a analog meter to check it also. The analog meter will show a bad spot more readily.) If yours looks like mine go for it.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
