Old 02-24-2020, 04:01 PM   #1
robpp
robpp's Avatar
Not another Vintage Air question
More than one Q
I spent alot of time going through the threads on here and Google without any luck.
I emailed Vintage air......no reply.
Prior Owner had system installed. Said to me....its one of those that never turns off. I left it at that.
Here is a pic of the controller.
The vertical switch on the left does nothing.
The rest are self explanatory. The fan speed, top horizontal, is totally variable.
Soon as I put key to on position, no matter what position I left it on, the air blows out of the dash. Maybe I guess until vacuum is built up?
Looking for wiring diagrams, operating manuals, installation manuals, etc for whatever GEN this system might be.
I tried Vintage Air site but all I find is newer or different looking controllers/
Thanks,
Rob
robpp is offline   Reply With Quote
Old 02-24-2020, 04:19 PM   #2
cebra
Re: Not another Vintage Air question
It may just need tuned, there is a single wire that needs grounded. You can find the instructions on the VA site. Do you have the clear plastic electronic "arms" on the back of the heater controls?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 02-24-2020, 04:21 PM   #3
cebra
On a side note, mine is a Gen IV and looks exactly the same as what you show but I suspect they all look the same from the faceplate.
Old 02-24-2020, 04:31 PM   #4
1971Stepside
Almost Satisfied
1971Stepside's Avatar
My guess is that yours is the old version like mine. Cable driven and not electronic. You can find the manual to that system still on their site. I think it is labeled old style under the 67-72 C10 page. I can look for link later for you. Sounds like you have a bad part. Call VA. They are always super helpful when I call them.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-24-2020, 04:36 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Not another Vintage Air question
I ran across this the other day and saved it.
I also took some screen shots and saved.
https://www.vintageair.com/instructi...ols)%20Ine.pdf
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-24-2020, 05:16 PM   #6
robpp
robpp's Avatar
Thanks Andy and all the rest. This will help.
I also recieved a response from Vintage Air to my email.
Told me where to find some #'s to further identify the system I have.
Also some pointers and things to look for now.
Thanks. Ill be back when i have more info and questions.
Old 02-24-2020, 06:44 PM   #7
Andy4639
Old member
Andy4639's Avatar
Me thinking out loud here.
In the picture I posted with the relays for the wiring kit. They are both 5 prong relays. If the PO hooked the hot wire to the 87A post by mistake this would supply power all the time as long as the key is on.
Old 02-25-2020, 09:34 AM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
I have one of the oldest systems in my C10, it might even be a Gen I. I have the factory air controller and mine uses cables on the sliders and the fan speed switch (the up and down one) works as it should, so my guess is that you have the slightly newer one that Cebra mentions above that uses plastic electric sliders on the the sliders instead of the cables.
I have the plastic slider system on my mustang. They look like the pic below (look under your dash, this should be obvious):
They're finicky. As Cebra mentioned, there is a "set up" procedure. You need to find the gray jumper wire and ground it out.
This is the procedure from Vintage Air. You need to follow it exactly:
http://www.vintageair.com/instructions_pdf/909950.pdf
My Mustang is still finicky at times. Sometimes it won't fully shut off, it will just run the fan at a super slow speed. Sometimes turning it all the way on high then back to off will shut it off, sometimes turning the car off and a restart shuts it off, and sometimes it works exactly as it should (this happens most of the time). The last time I "recalibrated" it, I didn't quite go all the way to the left (off). I kept it a hair off to make sure it turns off.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
