Old 07-11-2017, 11:55 PM   #1
Fourdy
Dual Mstr Cylinder?
I would really appreciate any help in finding a dual chamber master cylinder for my 64 GMC 2500 that would directly replace the original unit. I purchased one from Napa that I was told would work (M1880) but won't work as it has mounting bolt holes horizontally across the face not diagonal like the orig.
Thanks in advance,
Gary
Fourdy is offline   Reply With Quote
Old 07-12-2017, 12:22 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Dual Mstr Cylinder?
take a look at this thread, Maybe he can make you an adapter or possibly tell you if his will adapt the new master to your firewall
http://67-72chevytrucks.com/vboard/s...d.php?t=339081
Old 07-12-2017, 07:35 PM   #3
1958Warrior
1958Warrior's Avatar
May want to ask over on the 1960-1966 forum,
I'm sure that has been done over there many times
1958Warrior is offline   Reply With Quote
Old 07-12-2017, 09:15 PM   #4
Fourdy
I got it!! Napa #M1880 works perfectly. By removing the old m/c and trading the 4 bolts (two for the m/c and two for the internal bracket) with each other the new unit bolts on directly. I will lengthen the rod and all will be swell. I was disappointed to find that the brake line to the rear comes off of the passenger wheel area instead of just under the m/c. Oh well, can't have everything easy. lol Thanks to all for your help.
Gary
Old 07-17-2017, 06:14 AM   #5
55dude
55dude's Avatar
be sure and post pictures before,during and after! what application is the M1880 for?
55dude is offline   Reply With Quote
