10-16-2017, 08:43 PM | #1 |
Stewart Warner Vintage Sweep Tach Wiring
jb
10-22-2017, 01:30 AM | #2 |
Re: Stewart Warner Vintage Sweep Tach Wiring
I remember when Illinois had 2 L's [Ill. ] And California was 5 letters [Calif.] Boy, that's an old Tach. Hope it works, but the odds are good, because Americans really built their stuff good then.
What's the front look like? Or are there 2 different tachs? As far as wiring, it tells you. [+] to coil Positive [TACH if HEI]; [-] Neg to ground. The Black wire is your illumination bulb. Splice that into the grey wires under the dash to be controlled by the headlight switch dimmer, and go on with the lights.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-22-2017 at 01:39 AM. |
10-22-2017, 10:00 AM | #3 |
i want to see the front
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
