09-03-2019, 10:10 PM | #1 |
Which hole is for what?
I know one is for heater hose, one for water temp sensor. But not sure which and what the 3rd one is for.
1968 GMC 3/4 Ton 4x4 K20 / 2500 1971 Chevrolet Chevelle Malibu |
09-03-2019, 10:14 PM | #2 |
Who Changed This?
Re: Which hole is for what?
Hole labeled "A" is vacuum for the power brakes.
09-03-2019, 10:16 PM | #3 |
Carpe manana
350? A is for a vacuum fitting. Temp send unit typically in LH head with the hole in that non OEM water neck plugged up.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-04-2019, 10:46 AM | #4 |
Who Changed This?
Hole "C" would be for a thermal vacuum switch (emissions control), if the temp sensor doesn't go there (which it shouldn't). What year is the engine?
09-04-2019, 10:53 AM | #5 | |
So, I'm hearing that: A is for the brake booster B is for the heater hose C should be blocked off If that is right, then where should the water temp sensor go?
09-04-2019, 10:57 AM | #6 |
Technically, the temp sensor goes in the block on the passenger side, just below the headers, about midway back.
You could put your temp sensor in location "C" if you wanted to. Just make sure the other location is plugged.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
09-04-2019, 10:58 AM | #7 |
Water temp sensor is in the drivers side head between the front two exhaust ports just above the spark plugs.
1971 Custom/10 - 350/3 speed, Orange/White roof |
09-04-2019, 11:45 AM | #8 | |
Old member
Make sure the tempature sending unit is for a 71-72 truck are the gauge want read right.
09-04-2019, 01:31 PM | #9 | |
09-04-2019, 02:23 PM | #10 |
09-04-2019, 02:39 PM | #11 |
I just went and looked and there is nothing on the passenger side. On the driver side between the front 2 spark plugs there is a flat area cast into the block, but no hole was ever drilled. Maybe that's why the PO had that water pump neck with the hole in it?
Can I put the sensor there?
09-04-2019, 09:07 PM | #12 |
Does the side of your cylinder head between cylinders one and three on the driver side and cylinders six and eight on the passenger side have this water port plug below The arrow? This is where the temperature sensor is supposed to go.
If your cylinder heads do not have accessory holes on the ends of the cylinder head you have a set of 1968 or earlier cylinder heads that would’ve used an intake manifold with a second port in the front for the temperature sensor. (the 2nd picture shows '69 and later heads that DO have the accessory holes) 'The early heads usually do not have a port on the side of the cylinder head for a temperature sensor. On my truck a 69 with a factory 350 power brakes, AC, and turbo 400: Port A in your picture is used for vacuum to provide vacuum for the HVAC System, vacuum modulator on the automatic transmission and vacuum supply for the power brakes. A three-way tree screws into that port to supply vacuum for all three of those functions. You could use port "C" for a temp sender but I don't recommend it. That port is on the cold side of the thermostat and your temp gauge will not read actual engine temp until the thermostat opens. (the gauge will read cold while the engine warms up then spike to actual temp when the thermostat opens) AND if you try to use that port for the temp sender you must check and make sure the temp probe does not hit the thermostat beneath it as installed. If you have no other ports available for that temp sender I would find another intake manifold with 2 ports on the water side. Small block intake manifolds are dirt cheap and easy to find with the configuration you desire. Steve weim55 Colorado Last edited by weim55; 09-04-2019 at 11:39 PM. |
09-05-2019, 01:31 PM | #13 |
"Which hole is for what?"
That's what she.............Ah, never mind
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-05-2019, 02:57 PM | #14 |
I've used C for a thermo switch for radiator fans. It works well because it's not kicking the fans on until the thermostat is open anyways, and is "good enough" for the on-off temps in terms of accuracy on actual engine temperature.
09-05-2019, 03:10 PM | #15 |
The temp switch for the TCS system goes there. Did your truck come with the TCS?
72 C10 lwb fleetside -stock 350/350 combo |
09-05-2019, 07:32 PM | #16 |
The hole in the water neck is for a ported vacume switch.
09-05-2019, 07:39 PM | #17 | ||
"I ain't nobody, dork."
Every 67-72 SBC truck with an auto transmission I've owned or worked on had the modulator for the transmission plugged into that port. The vacuum for the brakes has always came off the back of the carb.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
09-05-2019, 07:54 PM | #18 |
This ^^^
09-05-2019, 11:26 PM | #19 |
We can close this now, Tony wins the contest!
09-06-2019, 09:42 AM | #20 | |
It took me a minute, but I had to realize my motor is supposedly out of an '88 Suburban, so maybe that's why mine is hooked up different? :shrug:
09-06-2019, 09:58 AM | #21 |
Haha, of course. Transmission Controlled Spark. It was an early emissions thing that didn't really do much. It would stop the vaccum advance from working until the engine was fully warmed up (temp switch in passenger side head) and the transmission was in high gear.
