Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-01-2018, 01:20 PM   #1
botoepfer
botoepfer's Avatar
donor hood needs some work
My 63 came with examples of rust at all four corners of the hood. I found an affordable donor that is in great shape rust wise but some bumps at the center front. My plan is to take the bracing/super structure out from these area as well at all other areas of the hood so I can treat with epoxy primer,, does anyone have any advice as to how to go about this Thanks
botoepfer is offline   Reply With Quote
Old 02-01-2018, 07:47 PM   #2
mongocanfly
Re: donor hood needs some work
it may just be me but I wouldn't even attempt to remove those....to much risk for getting it out of alignment when trying to put it back together...I'm assuming your referring to the "crossmember" that the hinges and hood latch attach to and the front to back strips...
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 02-02-2018, 10:48 AM   #3
botoepfer
botoepfer's Avatar
yes I am, I guess I will weld some washers to the dents and try pulling them with a slide hammer,, wish me luck !
Old 02-02-2018, 11:06 AM   #4
MARTINSR
MARTINSR's Avatar
Post some photos of the underside of the hood overall, and then some close ups on where it is welded to the skin along the sides, front and rear.
Only then we can discuss how you could do this or if you should do this. I am big into separating parts like this, but as mongocanfly said, this is a toughie!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 02-02-2018, 11:11 AM   #5
botoepfer
botoepfer's Avatar
Thanks I will get them up tonight !
Old 02-02-2018, 11:37 AM   #6
mongocanfly
yep..put up some pics of the dents...if theyre not to bad you might could cut a small hole in the cross brace and knock the dent out from the backside ...then weld the hole up without removing the brace...but it would help to see what you got...you might also get in contact with a bodyshop that has a stud dent puller and let them pull the dent for you
Mongo...aka Greg
Old 02-02-2018, 04:38 PM   #7
botoepfer
botoepfer's Avatar
donor hood images
Old 02-02-2018, 05:14 PM   #8
mongocanfly
id try a stud gun...but where that's at it wont be a easy fix..
Mongo...aka Greg
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
