03-14-2020, 11:51 AM | #1 |
Wires to remove ?
Does anyone have a list (or know where to find a list) of wires to remove from a stock 1963 GMC wire harness for a LS1 install?
Thanks,
48 CJ2A 63 1500 GMC (LS1 w/ Muncie 4spd) 68 RS Camaro 71 K20 BBC & granny 4 speed 95 2500 4x4 17 HD2500 4x4 Want => 67 C10 short bed w/ Manual Tranny |
03-14-2020, 12:16 PM | #2 |
Re: Wires to remove ?
Would it be easier to get a Stand alone harness?
If that's not in your budget or not your preference, I am sure someone on here has done this. Link to one supplier:https://www.psiconversion.com/produc...ng/500560.html .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
03-14-2020, 12:36 PM | #3 |
This truck I am working on is unmolested, very clean stock wiring. With that being said do you think I should swap it out because it is 57 years old ?
03-14-2020, 01:01 PM | #4 |
Depending on the level of you build (daily driver ---Nice----Show Quality).
I would consider a full harness swap with a stand-alone engine harness. .
03-14-2020, 02:20 PM | #5 | |
Old wiring has lots of resistance in it. It comes with age and unseen corrosion. |
03-14-2020, 09:09 PM | #6 |
OK
I feel the same, you pushed me off the stump I want to start the PU and make sure things are correct, while I am waiting for a quality kit to arrive, does anyone know which wires to eliminate under the hood ?
