Old 07-30-2023, 06:29 PM   #1
dmjlambert
dmjlambert's Avatar
Steering center link for 1969 C-10 pickup truck
Steering center link for 1969 C-10 1/2 ton pickup truck. Make your truck go in the direction you want it to go! This is not available as a reproduction or replacement part, if you need one you must get it used. This one is in good condition, just surface rust and grease. Can be used with conversion type disc brake spindles and 1969 tie rods, or can be used with stock 71-72 spindles if you use a 1969 outer tie rod in the inner tie rod position and use a conversion tie rod adapter/sleeve. $50 plus shipping or pick up in NW Houston area (Cypress near Tomball). Tie rods shown for illustration purposes. I will include the tie rods if you would like them, but I understand it is a good idea to buy new ones. Install center link with the tie rod castle nuts facing forward, not facing toward the crossmember.
dmjlambert is offline   Reply With Quote
center link, steering
