Old 07-12-2019, 08:40 PM   #1
Paul72
Paul72's Avatar
Look what I found under the valve covers!
I am trying to find the source of a miss that just showed up on my Blazer. I cleaned & gapped the plugs, new wires, cap rotor and it's still there...
I pulled the valve covers to see if maybe a rocker arm fell off and found this! I still have the miss for the moment, but am feeling a bit better about the power plant!
'72 Chevy K20 - 383/4sp/205 - finished!
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis)
Paul72 is offline   Reply With Quote
Old 07-12-2019, 11:31 PM   #2
Greasey Harley
Greasey Harley's Avatar
Re: Look what I found under the valve covers!
Sweet!
Kind of makes you want to pull the intake, to look for more cool roller stuff, eh?
Greasey Harley is offline   Reply With Quote
Old 07-12-2019, 11:46 PM   #3
franken
Apparently a PO had more money than brains. NP
Try opening the hood with the engine running after dark to check for crossfire.
Old 07-13-2019, 02:51 AM   #4
Martyt
Active Member
Wow, did not expect that!
72' Cheyenne K10 short bed, 4spd, orig eng and tran, am/fm radio, tilt, tach, manual throttle, med. bronze met. tow hooks, Factory Build Sheet, Protecto Plate, etc
Martyt is online now   Reply With Quote
Old 07-13-2019, 07:45 AM   #5
Grumpy old man
Grumpy old man's Avatar
Sounds like the surprise I found in a 350 small block I found for $300. When I opened it I found a new crank/cam/pistons along with all the visible parts turned out to be a 71 /350/ 4 bolt and after a little clean up I'm happy with it .
Old 07-13-2019, 11:59 AM   #6
BCOWANWHEELS
lobe on cam is bad bet ya
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 07-13-2019, 12:31 PM   #7
68Gold/white
Those rocker arms look to be Harland Sharp brand, some of the very best roller rockers!!!
68Gold/white is online now   Reply With Quote
Old 07-13-2019, 02:21 PM   #8
HO455
HO455's Avatar
Man some folks have all the luck. I'm lucky to find $2 in change under the seat of a new rig.
Congratulations! I hope your as lucky finding your missfire.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
HO455 is online now   Reply With Quote
Old 07-13-2019, 03:32 PM   #9
Rickysnickers
That makes two of us
Old 07-14-2019, 07:52 PM   #10
Mike C
Mike C's Avatar
I believe they say "Crane Cams" right on them. Cranes the original gold rocker and now Comps. The Harland Sharps are a more copper/orange color.
Cool find though!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-14-2019, 08:35 PM   #11
hjewell2
hjewell2's Avatar
I spy my little eye ,,, High bleed lifters by the pic I see, all rockers are on the valve seat position.
hjewell2 is offline   Reply With Quote
Old 07-14-2019, 09:35 PM   #12
BCOWANWHEELS
Bet the cam is plumb shot and all that metal has been pumped thru the engine...........pull oil filter, cut it open n inspect it..........jmo
Old 07-16-2019, 03:59 PM   #13
Paul72
Paul72's Avatar
Found the miss!
I swapped distributors and it went away - the points were getting worn out. Gonna have to find an HEI dist eventually...
Old 07-16-2019, 04:17 PM   #14
Ken O.
Originally Posted by Paul72 View Post
Found the miss!
That's one of the first things I did when I bought my 67 GMC. A lot of issues went away with an HEI unit.
Ken O. is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
