Old 06-27-2017, 10:05 PM   #1
Steve Cole
Late model brake booster install?
My doner truck (2005 Silverado) has a really nice looking brake booster / master cylinder on it, anyone know if this will install on my '68 without issues? Now that I'm thinking about it, I believe the lines are bigger on the '05, that would be a problem.
Steve Cole is offline   Reply With Quote
Old 06-29-2017, 06:38 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Late model brake booster install?
The nuts on the lines, will also be metric thread on the 05....IIRC. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-29-2017, 11:16 PM   #3
solidaxel
solidaxel's Avatar
I had the same issue with a Hydroboost with a metric M/C I just used some pre made short brake lines with the right flare nut on the lines that fit the M/C and cut the other end off and 3/16 nut and double flair for the Pro Valve, worked for me!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-29-2017, 11:31 PM   #4
Captainfab
60-66 Nut
You might find this helpful to achieve a correct and safe installation.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484
