11-19-2011, 10:52 PM | #126 |
Re: Project Cheap Thrills!
We'll run em` when you're finished Nick.
That 506 medium blue poly is awesome!
project: "my happy mess" |
11-19-2011, 11:32 PM | #127 |
Hazel's engine is a drooler isn't it? n2billet did a great job in the engine bay! I had a 68 Camaro in the early 90's. I had dreams of doin a restomod (?) look to that engine. Never got around to it. n2billet inspired me to do it on this one.
We'll line 'em up if I can chuck a big block in it! I wanna see how squirrley a SWB big block C10 can get!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
11-20-2011, 12:50 AM | #128 |
Yes, it is. Very sharp/clean.
11-23-2011, 07:48 AM | #129 |
I have a set of ECE 1" drop front coils you can have if you want them. New condition.
11-28-2011, 12:32 AM | #130 |
Grandpa in the rustmobile...
TTT I like your style builds, any updates
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-28-2011, 12:45 AM | #131 |
Nothing new yet. I've been doing a lot of planning and looking around for cool pieces to add to the wish list. I've got some great ideas for Chapter 2 of this build. I had to take it home because they are adding a car wash and detail bays to my dealership so parking is at a premium. For the moment its chillin' in the driveway.
12-29-2011, 09:05 PM | #132 |
Man, it been over a month since I last posted! I gotta get moving! Well I had some extra time tonight. I had to wait for the alignment rack so I figured I'd cut out my windshield.
It had a big gap at the top just over your left eye (about 2" gap) and I bought a seal sometime ago. Its getting cold outside so I haven't driven the truck much so I figured this would be a good time to see what kind of rust damage was underneath. Boy was I suprised! What luck, surface rust!! Nothing else. I expected having to cut out cancer and put new metal in. I'm gonna clean up the area, repaint and do my drip rail seam sealer and reinstall the windshield all at once.
12-29-2011, 09:06 PM | #133 |
12-29-2011, 09:25 PM | #134 |
Wow, has been a while. Looks like it'll clean up Real nice!
12-30-2011, 12:41 AM | #135 |
VA72C10
That windshield area will make a lot of guys jealous Will look great cleaned up!!!
Looking for a 67-72 swb or blazer project in or around VA. |
12-30-2011, 07:50 PM | #136 |
So tonight I scrubbed, scrapped and buffed the windshield. Although I wasn't able to get all the wiper marks out, it did come pretty clean. I started with a polishing compound because I didn't want to start out too agressive. I had the buffer set at 1000 RPM. I tried the next step up and then Kevin, our lead detailer, gave me something called "Diamond cut" (?) and suggested I step up to 1400 RPM. In the end I think it worked out pretty good seeing as how I wasn't expecting much.
I did check and I can get a PPG glass for $100.00. I know it seems funny to put a bunch of labor into an old windshield when a new one is so cheap but I just wanted to say I tried it. As the truck gets nicer I'll install a new one. I should have taken a photo of the finished product but I left without doing it! I'm gonna be back at it tomorrow so I'll post one then.
12-31-2011, 04:40 PM | #137 |
So I got back to it today. I cleaned the windshield channel the best I could and used some rust converter (for the surface stuff) on the channel and forward part of the dash. Come Monday I'll paint the channel and the top of the dash, let that dry and reinstall the glass with a new seal.
I also applied the seam sealer to the gutter channel. Man o' man do I hope that stuff levels out better than it did! I saw a couple of places that looked ok but I'm not sure how its gonna turn out.
12-31-2011, 04:41 PM | #138 |
Several others...
12-31-2011, 04:48 PM | #139 |
Can't wait to see how it levels out. Thanks for posting product image. Windshield looks clean.
12-31-2011, 06:18 PM | #140 |
eek lol i hope it levels too
12-31-2011, 07:26 PM | #141 |
Yeah, I have never done this before nor have I seen it done. The tip was an epoxy mixing tip and I wasn't sure if the tip should be modified. If I had it to do over again I'd trim the tip to allow for one big fat self-leving bead. I probably woulda masked the roof to aloow for a nice clean line. Oh, well. Lets see how it works out.
12-31-2011, 11:10 PM | #142 |
VA72C10
Did you get to check it out tonight to see how it leveled out?
Happy New Year!
12-31-2011, 11:19 PM | #143 |
Nope, did it at work and left. The shop closed early for New Years. I'll know monday.
12-31-2011, 11:21 PM | #144 |
Label says "Working time 10 minutes" and "Paintable in 20-40 minutes", that implies it is finished leveling in 15 minutes.
01-01-2012, 12:11 AM | #145 |
Just found this:
The only thing I didnt do was zig zag when applying. Oh well. You can't really see it unless your tall. I'll figure out to fix it.
01-02-2012, 07:27 PM | #146 |
How'd it turn out?
01-02-2012, 07:40 PM | #147 |
It never self leveled. Funny, you'd think that something that said "Self-Level" would self level but I guess I was askin too much. It seems like it is sandable so I'll hit it before I spray it. I wish I had found that video before I laid the stuff down. The zig zag action is the trick.
01-02-2012, 07:58 PM | #148 |
True. It looks like you're in a climate controlled shop, so temp. shouldn't have had a negative effect.
Maybe you can sand it down and fill in the low spots by reapplying. Then sand and paint over to finish it off. Like you said, not noticeable, but you do want a good seal.
01-02-2012, 08:02 PM | #149 |
Oh, its sealed alright. It just needs to be sanded down. Hopefully, it'll sand well.
01-02-2012, 10:29 PM | #150 |
I have seen that done with house caulk before lol so that don't look so bad keep it up truck looking good
David Fultz - Berlin Ky 79 K5 2wd - Project 86 GMC 1500 LWB- Shop Truck 84 Chevy K-20 Hugger Orange and Silver- Wifes Truck 2018 Ram 2500 - Tow Rig 79 Chevy C-30 SRW- Bought new by Uncle |
