Old 05-17-2013, 06:05 PM   #26
1966chevy
1966chevy's Avatar
Re: 1966 chevy truck engine swap to LS1
I also filled in the gas tank area with more storage, speakers and fire extinguisher. Molded the wood with fiberglass for the extinguisher and carpeted it. Hope fully the seats will go in this weekend.
1966chevy is offline   Reply With Quote
Old 05-17-2013, 06:09 PM   #27
1966chevy
1966chevy's Avatar
I also molded some kick panels were the vents use to be. I will try to get some pictures posted of them.
Old 05-17-2013, 06:25 PM   #28
chevyrestoguy
chevyrestoguy's Avatar
WOW!
That looks great! I want to know more about:
The Clock.....you painted the face? Did you use a vinyl mask? How did you find the font and the correct color? It looks factory!
The Voltmeter conversion.......how difficult was the conversion? I have a few extra '73-'87 voltmeters in my stash. Great idea.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-17-2013, 11:23 PM   #29
1966chevy
1966chevy's Avatar
Amp to voltmeter conversion was found here and it worked perfect.
http://67-72chevytrucks.com/vboard/s....php?p=4611415
Old 05-17-2013, 11:44 PM   #30
1966chevy
1966chevy's Avatar
As for the clock, I mixed some paint up and color matched it. The font was there I colored them in, then I painted the chevy Bowtie that was by hand. Built them in 2004. Then I stored it until 2013 when I had all the parts to install everything. Here are some pictures of the clocks. I made two and I sold the worst of the two years ago. I'm shocked I haven't seen it in a show or something.
Old 05-17-2013, 11:47 PM   #31
1966chevy
1966chevy's Avatar
This is the one that I sold. The one I installed in my truck has a chrome bezel and this one is painted silver. The one below had all the gauges, but didn't have a tach installed and it was the worst of the two that I built. Still look pretty good, through!
Old 05-18-2013, 12:05 AM   #32
1966chevy
1966chevy's Avatar
I also molded some kick panels or would say modified aftermarket panels, where the fresh air vents use to be. Here are some pictures. I removed the speaker pop outs which was at the bottom of the kick (you can kinda see the round portion a little bit) and I moved it up to the vent holes and closed in the top portion of the vent. Sanded it, used plastic filler, sanded it again spray it with primer, then textured paint and then painted it like the dash, flat black sealer. I attached the with a product I purchased at "Rod Doors" to hold door panels on. Worked great.
I close up the vents because I have new aftermarket AC and fresh air would affect the performance of the AC unit. No more fresh air, put the window down or turn the fan on.
Old 05-18-2013, 12:11 AM   #33
Captainfab
60-66 Nut
Very nice work
Old 05-18-2013, 09:34 AM   #34
LT1 Burb
LT1 Burb's Avatar
Nice job, especially on the chevy emblem on the clock.
LT1 Burb is offline   Reply With Quote
Old 05-25-2013, 07:04 AM   #35
65 wonton
Nice install.
Could you comment (sources and part # would much appreciated) on the engine perches, motor mounts and headers. Seems these are the problem areas in LSx conversions.
65 wonton is offline   Reply With Quote
Old 05-25-2013, 01:15 PM   #36
1966chevy
1966chevy's Avatar
Look on Page 1 of this thread on item #21 talks about it. If you need more let me know. Thanks
Old 05-26-2013, 03:57 AM   #37
66C06
66C06's Avatar
which lokar gas pedal unit did you use? I called them and they said they didn't have anything that would work on the 66.
66 SWB Stepside: Project C-O6
06 ZO6 MSM 6spd 562/520rw N/A
06 Caddy CTS The Daily
07 Hayabusa - absolute chaos
66C06 is offline   Reply With Quote
Old 05-26-2013, 12:52 PM   #38
1966chevy
1966chevy's Avatar
I use the 67-72 brake pedal. It worked fine. I also called them to let them know they could change the description for 60-72 but they said they would look into it. LOK-BAG-6166
Old 05-26-2013, 03:47 PM   #39
78f1hundo
Which steering column did you use?
65' Chevy C-10 Shortbox
78f1hundo is offline   Reply With Quote
Old 05-26-2013, 04:49 PM   #40
1966chevy
1966chevy's Avatar
Ididit steering column and made it power at the same time. I used a 67-72 steering box and adapter plate.
Old 05-26-2013, 11:43 PM   #41
66C06
66C06's Avatar
Awesome! That solves some problems for me!,lol. Was the instal straight forward? any modification to the 66 brake mounting assembly?
Old 05-27-2013, 12:29 AM   #42
66C06
66C06's Avatar
Which throttle assembly did you go with?
Old 05-27-2013, 07:12 AM   #43
RoyL
RoyL's Avatar
[quote=1966chevy;5751242]
Originally Posted by davidb1 View Post
That looks great!
Can you describe what you did for motor mounts?
The Truck Shop "truckandcarshop.com" in Orange cal. Has a tubular set, that bolt to the same holes in the frame. You can choose to mount in forward or in the stock location. Either way you are going to have to deal with lengthening the drive shaft. I had to shave a little on the side weld was to big for the motor mount. I called to report it issue to the company. Who knows if it will go anywhere. They were power coated and I sealed the grind it with some Black POR15.
If you have a V8 you can use your same set, but I wanted to upgrade to the newer style motor mount.
Nice job! This one on page 121 of their catalog?
63-1281041
http://www.truckandcarshop.com/trucks60_72/t60_121.html
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 05-27-2013, 01:14 PM   #44
1966chevy
1966chevy's Avatar
Lokar throttle cable and throttle pedal. Lining up the cable with the pedal would be the hard part but not to bad. Works and looks great with the brake pedal. Here are the web site for the parts I used:
http://lokar.com/product-pgs/throttl...le-cables.html
http://lokar.com/product-pgs/throt-a...or-pedals.html
Old 05-27-2013, 01:16 PM   #45
1966chevy
1966chevy's Avatar
Engine mounts,
I had to cut a little of the frame length wise just so the holes would line up. I used the existing frame mounting holes.
Old 05-27-2013, 01:20 PM   #46
1966chevy
1966chevy's Avatar
Tilt wheel column,
Went in with no problems, not affecting the brake assembly at all. I had to use a length of steering bar with a u-joint assembly to the new steering box.
Need pictures let me know.
Old 05-27-2013, 11:14 PM   #47
66C06
66C06's Avatar
Thanks for the info! I am enjoying your build!
Old 05-27-2013, 11:55 PM   #48
Bigdog44
Where did you find that console?
Bigdog44 is offline   Reply With Quote
Old 05-28-2013, 12:09 AM   #49
1966chevy
1966chevy's Avatar
Console, Behind the seat? I hand built it out of MDF wood, I integrated speaker boxes, fire extinguisher and center storage holder. There is absolutely no storage in this truck, so this helped out a lot. The box is a different color carpet on camera but with a naked eye its hard to tell . Plus, Its pretty hidden behind the seat so you can't really see the different color. I used different seats. 2001 Dodge seats, 3 seater, with a center fold down storage. I will get some pictures posted tonight.
Old 05-28-2013, 01:06 AM   #50
1966chevy
1966chevy's Avatar
Here are some pictures of the seats is used.
