Old 11-14-2015, 03:48 PM   #126
Skips66
Re: 1966 chevy truck engine swap to LS1
GREAT looking build! Where did you relocate the battery ? And your AC deflector balls look terrific! Have you found a plastic plater or replacements?
Thanks for sharing!
skip
Skips66 is offline   Reply With Quote
Old 11-22-2015, 05:38 PM   #127
joesscamaro
Older thread, I know...but, what kind of radiator and fan set up did you go with? Don't remember reading about that
joesscamaro is offline   Reply With Quote
Old 12-19-2015, 10:26 PM   #128
65C10-4.8
Very nice, very clean. What did you use for the cold air intake set up, a kit available somewhere or pieced together ?
65C10-4.8 is offline   Reply With Quote
Old 12-19-2015, 11:31 PM   #129
1966chevy
1966chevy's Avatar
Thanks,
I used K&N 77 Series Polished Air Intake System 99-07 Chevy Cadillac GMC V8 Truck & SUV at O'Reilly Auto Parts store.
1966chevy is offline   Reply With Quote
Old 12-19-2015, 11:41 PM   #130
1966chevy
1966chevy's Avatar
I ordered a replacement 1965 Impala Aluminum Radiator, modified the mounts on my truck and had a couple extra bungs added for the steam line, I also had a fan shroud custom built for it. I believe its a 14 inch fan, I think it's a 2000 cfm, pull fan.
Old 12-19-2015, 11:45 PM   #131
1966chevy
1966chevy's Avatar
Thanks for sharing!
skip
I relocated the battery under the bed, passenger side. Battery box that drops down for maintenance, etc. The terminal under the hood are for trickle charging and jump starting.
Ac deflector ball were re-chromed back east, plastic plater/chrome. I could find the details on that if you want. I could not find replacement deflector balls any where.
Old 04-23-2016, 02:20 PM   #132
1966chevy
1966chevy's Avatar
My product is the “silent gate” and it has been noted in Hot Rod and Classic Truck Magazine. My product was mentioned on the Hotrod network magazine, on-line. As the Silent 'Gate.
http://www.hotrod.com/features/1509-...ruck-products/
Also mentioned in Classic Truck magazine Feb 2016 issue, released on the stands Nov 20th 2015. Check them out! Thanks
Look back on the post for details. It also can be see for sale on Ebay.
These are Very quite while opening and closing the tailgate.
See my attached link if your interested in purchasing"
I also in the works on building 58-66 Fleetside trunnion hinges.
http://www.ebay.com/itm/171709176937...#ht_559wt_1094
I also in the works on building 67-72 Fleetside trunnion hinges.
http://www.ebay.com/itm/171709178881...#ht_430wt_1094
I also in the works on building 58-87 Stepside trunnion hinges.
http://www.ebay.com/itm/171718930810...84.m1555.l2649
Hurry and purchase a set, while supplies last!
Old 04-23-2016, 11:44 PM   #133
Captainfab
60-66 Nut
Congrats on the recognition
Old 04-24-2016, 04:04 PM   #134
ole dollor
ole dollor's Avatar
Congrats my friend ......very nice product .....Don
ole dollor is offline   Reply With Quote
Old 11-06-2016, 09:48 PM   #135
1966chevy
1966chevy's Avatar
My product is the “silent gate” and it has been noted in Hot Rod network magazine, on-line and Classic Truck Magazine.
Products are available on line at tdtrunniondesign.com as well as for sale on Ebay noted below.
#c10source #c10 #chevytruck #truck #tdtrunionsdesign
Old 01-04-2018, 02:08 PM   #136
1966chevy
1966chevy's Avatar
I did this in 2012/2013 but I wanted add some pictures on what was completed to basically catch you up. Gas tanks and rear Frame clean up.
Old 01-04-2018, 02:10 PM   #137
1966chevy
1966chevy's Avatar
Bed swap using my driveway cover as a hoist, lol! No laughing it worked!
Bodywork and tailgate!
Old 01-04-2018, 02:12 PM   #138
1966chevy
1966chevy's Avatar
Bodywork, Rockers. Replaced them, I hand built them, no kit.
Old 01-04-2018, 02:20 PM   #139
1966chevy
1966chevy's Avatar
Originally Posted by 1966chevy View Post
No not for what I wanted to do the frame rail was in the way. You would have to cut and reinforce the frame rail to have kept it in the lower position. So I guess you could if you reinforced the frame.
Doors - One-Piece glass project! It very long and tedious process, fitting and refitting, you need patients, you can't rush this!
Old 01-04-2018, 02:22 PM   #140
1966chevy
1966chevy's Avatar
Fitting the windows, I made a template. I also made door stops that are flexible.
Old 01-04-2018, 02:28 PM   #141
1966chevy
1966chevy's Avatar
Engine bay bodywork and swap.
Old 01-04-2018, 02:35 PM   #142
1966chevy
1966chevy's Avatar
Here are some interior details! Custom made vent plugs, Speaker box, customer redesigned kickers moving speaker to the vent hole. So you won't lick the speaker and I'm not using the vents anymore. Remember I also closed up the cowl vent on the hood. See past pages for picture on that.
Old 01-04-2018, 02:39 PM   #143
1966chevy
1966chevy's Avatar
Here are more interior details! AC vents with custom plenum to work with the Old Air Product AC lit I used. I love the stock controls,with the little button for the AC or/off.
Old 01-04-2018, 02:43 PM   #144
1966chevy
1966chevy's Avatar
Here are some bodywork and paint pictures.
Old 01-04-2018, 02:47 PM   #145
1966chevy
1966chevy's Avatar
Here is the final pictures, for now I don't know if anyone is really finished. Sense these pictures where taken I have lowered it 2 1/2 front spindles, and 3-inch rear coil.
Next show or when I have it out next, I will take some pictures of the stance and post it.
Old 01-04-2018, 11:48 PM   #146
Captainfab
60-66 Nut
Nice work
Old 01-05-2018, 10:57 AM   #147
Clyde65
Clyde65's Avatar
Very nice work!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-05-2018, 11:59 AM   #148
sixty4bigwindow
sixty4bigwindow's Avatar
That is AWESOME. Question for you, I have a set of shaved doors with no glass, was considering the solid window. How hard was the swap to that? Would you do it again??
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck...
My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023
sixty4bigwindow is offline   Reply With Quote
Old 01-07-2018, 07:18 AM   #149
northern 85
northern 85's Avatar
Very very nice!!!
northern 85 is offline   Reply With Quote
Old 01-30-2018, 12:56 PM   #150
1966 GMC
1966 Chevy you mentioned in a post you had not taken any pictures of the computer mounted with the air unit. Is there any way you could post some pictures because i was planning on the same setup as you did. Thanks in advance.
1966 GMC is offline   Reply With Quote
