Old 05-26-2015, 10:37 AM   #26
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 GMC C30 panel truck
Liking the progress. That's gonna be one mean panel when your done.
Old 05-26-2015, 10:40 AM   #27
AJCK87
Working on cutting out this panel, going to make a new piece.
AJCK87 is offline   Reply With Quote
Old 05-26-2015, 12:50 PM   #28
AJCK87
Read for some fresh steel
Old 05-28-2015, 01:43 PM   #29
AJCK87
On to rear door latches and hinges, time to fire up the lathe.
Old 05-28-2015, 01:44 PM   #30
AJCK87
Old 05-28-2015, 01:46 PM   #31
AJCK87
The latch turned out awesome and so did the first barn door hinge. Used custom turned brass bushings and shoulder bolts for the pin. Tough enough to last another 50 years hahaha
Old 05-28-2015, 01:47 PM   #32
AJCK87
Old 05-28-2015, 01:49 PM   #33
AJCK87
Got it down to about 4hrs per hinge, with all the fit and finish filing. 5 down, 3 to go!
Old 05-28-2015, 01:50 PM   #34
AJCK87
Turning out some bushings....
Old 08-28-2015, 11:51 AM   #35
AJCK87
Progress! I have been back on the panel here and there. Where does the time go in the summer? I have the barn door hinges complete, they turned out awesome and glide super nice with the brass bushings.
Old 08-28-2015, 12:01 PM   #36
AJCK87
Front fender supports. Pleased that these are in such good shape.
Old 08-28-2015, 12:05 PM   #37
AJCK87
Referbished the licence plate light. The rubber gasket was in good shape, cleaned up the lens and housing. Changed out the conventional bulb for a LED panel.
Old 08-28-2015, 12:10 PM   #38
AJCK87
New master! Didn't ask for Chrome, should work out though hahaha
Old 08-28-2015, 12:14 PM   #39
AJCK87
The booster. Mmmm shiny.
Old 08-28-2015, 12:15 PM   #40
AJCK87
The new bracket.
Old 08-28-2015, 12:18 PM   #41
AJCK87
Front door hinges mounted. Passenger door is opening and closing well now.
Old 08-28-2015, 12:22 PM   #42
AJCK87
The drivers side door in cleaned up and mounted. Still have to do the sheet metal work on the doors. The hinge adjuster plates on the door are frozen and need some persuasion. Some sheet metal work to be done, it's in really great shape for its age.
Old 08-28-2015, 12:31 PM   #43
AJCK87
Removed the dents, welded a couple of holes closed and removed the rust on the inside door panel. The whole truck, inside and out, will be white and Neptune green. White top and green from the window line down. White along the recessed line on the interior and the rest will be Neptune green with grey upholstery. Working towards installing the drive line, sealing off the cab, addressing the rust and getting the truck on the road. Paint may have to wait.
Old 08-28-2015, 12:34 PM   #44
AJCK87
More parts that need attention plus a couple of front doors I picked up in Chilliwack.
Old 08-28-2015, 06:01 PM   #45
TJ's Chevy
TJ's Chevy's Avatar
Nice work! Looks good!
Old 08-28-2015, 06:14 PM   #46
AJCK87
Thanks! I had to catch up on my posts. Yours is coming along nicely!
Old 08-28-2015, 06:19 PM   #47
AJCK87
First blood hahaha, mashed her with the 4lb sledge. Does anyone know a good trick for getting out stubborn body mount bolts? The long lag bolts are seized in the steel collars in the rubber mounts .
Old 08-31-2015, 11:06 PM   #48
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Ouch! That looks painful. Do you have access to a torch to warm the body bolts? Heat usually helps.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 09-01-2015, 01:29 AM   #49
AJCK87
Yeah I will have to give the torch a try. Little concerned about the wood bed, I want to preserve it to use as a template for the new floor boards.
Old 09-01-2015, 01:32 AM   #50
AJCK87
Refurbished the steering wheel. Wouldn't mine hitting it with some more paint. Anyone have some good suggestions what to finish it with?
