Old 06-01-2017, 06:58 PM   #26
Backpayne
Re: Thoughts of swapping in an Olds 455 w/400 trans in '64?
Got the engine disassembled and the bottom end looks good...whew.
Backpayne is offline   Reply With Quote
Old 06-18-2018, 11:10 AM   #27
Backpayne
It has been a little over a year since my last update, and I'm still not finished. The crank was actually bad but found an unmolested one. Took all to machine shop to have block bored over and crank ground .1 under. Purchased heads that were rebuilt a few years ago but I did upgrade the springs to work best with my new camshaft. Everything else is new, also. Getting close but life is busy!
I am also rebuilding a th400. First time ever rebuilding a transmission and engine, but all seems to be going well, just slow.
Old 06-18-2018, 11:14 AM   #28
Backpayne
Darn picture is sideways.
Old 06-18-2018, 12:10 PM   #29
Killer Bee
Killer Bee's Avatar
had a couple of 455 olds and a 455 pontiac, both great engines in their own right..
here's a little 455 olds tire smoke for inspiration, good luck with your project!
Old 06-18-2018, 12:25 PM   #30
mattfranklin
mattfranklin's Avatar
Originally Posted by HAULIN' IT View Post
Agreed!
Beautiful!
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 06-18-2018, 12:27 PM   #31
mattfranklin
Looks great! Slow and careful is ok when you are building. My '70 LT-1 350 is 80% done. Slow and careful. Maybe late this summer for me.
Old 06-18-2018, 12:43 PM   #32
Backpayne
I'm afraid I will be doing that often.
Old 06-18-2018, 12:47 PM   #33
Backpayne
I definitely don't want to rush anything on this. Way too much money invested to screw this up. I just hope it all goes without any issues on 1st fire-up/cam break-in. I think that is what terrifies me.
Old 03-18-2019, 10:31 PM   #34
Backpayne
I thought I would provide another update. All is going well just really slow.
I'm finishing up the switch panel for the run-in stand then the exhaust and connecting the radiator. Very close to firing it up, but I am very nervous.
Old 03-18-2019, 11:51 PM   #35
WorkinLonghorn
WorkinLonghorn's Avatar
WOW, looking great. What are you going to use for axles. That thing will twist your current ones like licorice candy.
I had a Olds 455 in a 232" 5000+ Lb 98 Regency but it was severely burdened with Calif smog stuff including a clogged Cat. Still never had to work hard getting from one gas station to the next. Great motors. I see a very fun future for you. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 03-19-2019, 12:30 AM   #36
Killer Bee
Killer Bee's Avatar
can't quite make it out in your pic, but that's 396021F right?
days of boneyarding 30 years ago to find a cracked block replacement and still remember that
keep us posted, Dr. Oldsmobile would be proud
Old 03-19-2019, 12:36 AM   #37
Backpayne
I have a 12 bolt from a '68 with a rebuilt factory lsd. This thing should be scary fun.
Hot damn you're good! It sure is! This thing has been fun to build but a hell of a lot more expensive than I had dreamed, hence the taking the build slow.
Old 03-20-2019, 08:07 PM   #38
garyd1961
I've had two 455 Olds and a 455 Pontiac over the years. It was my way of building a hotrod back in the day. Take a 455 out of a big 4 door and put it in a Cutlass size body and instant hotrod. The only reason I don't have one now it the 350 is so much easier and cheaper to build but I like what you are doing.
garyd1961 is offline   Reply With Quote
Old 03-21-2019, 07:33 PM   #39
68Gold/white
What intake is that???
Do you now have adjustable rocker arms???
Carry on, great job!!!
My other vice is Pontiacs, Oldsmobiles are awesome also!!!
What gear is in the diff you plan to use??? Really won't matter, tires won't get any mercy regardless of ratio...LOL
68Gold/white is offline   Reply With Quote
Old 03-21-2019, 07:39 PM   #40
Backpayne
Intake is an Airgap and have new adjustable rocker arms, too.
Gear ratio is 3.73 but will possibly swap to 3.08.
This has been a fun 1st build.
Old 03-21-2019, 09:26 PM   #41
truckster
truckster's Avatar
I'm glad you decided to paint it Oldsmobile blue. I've always loved that metallic blue engine paint. It looks really good.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-22-2019, 02:43 PM   #42
Backpayne
It is broken in and running great. I still need to time it a little better and fine tune the carb, but she is sounding good. Here is a video of it idling at 800 rpmm
https://youtu.be/q10_XxiUbWM
Old 04-22-2019, 11:25 PM   #43
Captainfab
60-66 Nut
That does sound really good It ought to move your truck along quite well. I hope you have some extra money set aside for a couple sets of rear tires
Old 04-23-2019, 08:49 PM   #44
garyd1961
Nice motor, I will give you one thing you have a lot more patience than I have which is probably a good thing, lol.
Old 04-24-2019, 12:24 PM   #45
68post
Oh Boy !! It should make 550 ftlbs or more. Be careful of getting any good traction because that 12 bolt is a weak cousin to the passenger car 12 bolt.
I have alot of Olds parts and engines on hand, just none for sale. My moniker "68post" is for my 1968 442 post coupe that sits in my garage.
You're gonna have a ton of fun sliding sideways. But the 455's don't take high rpm well without some changes, I'd set a rev limiter to about 5,200 rpm and ENJOY !!
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 04-24-2019, 08:07 PM   #46
Backpayne
Yeah, I'm going to have to be careful with the throttle on with this beast, especially with the lsd and corners. I've never had a vehicle with this much power, but man am I excited. I don't plan on dragging it or racing it, but I've heard that high revs can suck the oil pan dry and cause some catastrophic problems.
With the length of my th400 (long shaft) I'm hoping I'll be able to find a one piece driveshaft from a different vehicle that will fit without modifying, other than u-joints. I should be installing engine and trans within the next couple of weeks then I can measure the length needed.
Building the engine rather than buying makes me quite proud to put in to my '64. I can't wait!
Old 04-25-2019, 09:59 AM   #47
68post
The actually problem is the tremendous piston speed (a result of the 4.25" stroke ), and piston/con rod weight combined with the strength of the stock rods, and the fact that the rod journal is 2.5" dia/mains 3.0".
Not necessarily sucking the pan dry. But...you ain't racing !
I applaud your efforts !!!
Tim K.
Old 04-25-2019, 11:22 AM   #48
Killer Bee
Killer Bee's Avatar
here's some inspiration from someone else that swapped a 455 olds into a C20
https://seattle.craigslist.org/kit/c...870834293.html
Old 05-11-2019, 05:02 PM   #49
Killer Bee
Killer Bee's Avatar
how are you doing OP?
here's another one for inspiration
http://67-72chevytrucks.com/vboard/s...d.php?t=783614
Old 06-16-2019, 02:39 AM   #50
naphtali5725
naphtali5725's Avatar
glad to see someone else putting an Olds 455 in!
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
