Old 01-29-2017, 09:08 AM   #351
_mg
Active Member
_mg's Avatar
Re: 64' K10 Project Long Bed
Originally Posted by 60-66 View Post
Your collection of everything still amazes me. Thanks for sharing!
_mg is offline   Reply With Quote
Old 02-11-2018, 02:21 AM   #352
aotte1
Jon,
A little late thanking you your post on the fan clutches.
Not much progress, last year. The body panels are at the painter, forever, still waiting. Mainly painting is what waiting on to finish. Would be great to paint myself, however, no more painting for me, health reasons.
Past year, found a pair of 17.5 6 lug wheel, working on getting 2 more, also a little body work, metal bumping on the cab. Finalized the original brake lines layout, with the help of Lyle. This truck had the brake lines highly modified, along with hydraulic brake lock added. Engine almost rebuilt, trans is rebuilt. Researched and have made decision on steering arm geometry, for steering arm.
Also, added a four post lift to garage, should have done years ago.
Started another project while waiting for truck to be painted. Short bed C10 truck. Building pretty much stock, with a few upgrades. Will be a driver.
Les
aotte1 is offline   Reply With Quote
Old 02-11-2018, 09:33 AM   #353
_mg
Active Member
_mg's Avatar
Hi Les, good to hear you are making some progress. Which 4-post did you acquire?
Mike
Old 02-13-2018, 12:29 AM   #354
aotte1
Mike,
The four post is made by "Direct Lift" which is a "Rotary" company. It is I think a 9000 # capacity, "Pro Pack 9 Plus". Will get the specification on it. Very sturdy, like it a lot, would buy again. One of the features for choosing it, is the space between the runways, wider then most, more room to do stuff. It is made in China at a factory owned by Rotory, factory also make Rotory components too.
Key for me was that factory is owned and operated by Rotory, vs certain other brands that send out a request for bids to build a certain number of lifts. Once they sell through these, they do another request for the lowest price to build another set of lifts. Some of them are not certified to industry standards.
Delivered by truck, must have decent size fork lift. The package is heavy and long. Main issue is its length, and may not be able to center on fork lift ( big rotation force) unloading from tractor trailer. Then loaded on roll back and delivered to garage. Roll back dropped it off in garage stall. Unloaded onto three 1000# dollies. Used engine hoist with strap slings to unpack package. The slings had a large distance between the two end on the parts, e.g. runways, to keep part being lifted under controlled.
The columns can be moved by two people. Planned placement of parts, because only had access to one side of lift.
Also has sliding hydraulic lift, it allows the vehicle to be lifted off runways, to work on suspension, brake stuff.
Purchased with a discount negotiated at time of purchase.
Les
Old 02-13-2018, 12:52 AM   #355
aotte1
A few more photos.
Old 02-13-2018, 12:56 AM   #356
aotte1
One more detailed photo.
Old 02-13-2018, 07:12 AM   #357
The Rocknrod
Moderator
The Rocknrod's Avatar
Nice lift, I always wanted one like that. I went with a Kwik Lift when I had a normal garage like that due to limited height to lift. And when I moved Kwik Lift bought it back.
Old 02-14-2018, 01:26 AM   #358
aotte1
Rocknrod,
Thanks for the lift complement. Do you have space for a lift now?
You had to be good ( too cool for school) to be a Master Chief, congratulation on your Navy career.
Lucky this garage is 11' tall, so lift works ok. Moved the garage door above the lift and installed a high lift garage door track, about 4" off ceiling, with a side opener. Not shown in photos above.
Les
Old 02-14-2018, 03:21 PM   #359
61K10
61K10's Avatar
Nice lift Les. My buddy had one in his shop and a customer bought one for his garage. Well i got to install it. You are right, Heavy. It was dropped in front of his house. Long story short, my buddy and i had to move it 50 feet to his garage. not fun. Enjoy your lift.
Kimble
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-15-2018, 08:16 PM   #360
_mg
Active Member
_mg's Avatar
Thanks for the information Les, looks like an option for me. Always looking for stuff for the time when I FINALLY get time to work on my truck.
Mike
Old 02-16-2018, 02:15 AM   #361
aotte1
Kimble,
Thanks for the complement on the lift. Two people moving one 50 ft. is a lot of work.
mg,
You are welcome, for the information. From my experience, you will enjoy it a lot. Makes so many projects a lot easier.
Thank,
Les
Old 06-10-2019, 12:38 AM   #362
raylube
raylube's Avatar
Any updates?
raylube is offline   Reply With Quote
Old 10-11-2019, 11:57 PM   #363
aotte1
Ray,
Thanks for the request. Not much new to report on the 64’. Do have the 64’ cab on the frame. Will post new photos. My grandson and I are planning to get back on it soon. We have been working on our 66’ C20 Custom Camper, this past few months. Lots of body work on the cab/fenders. Putting 66 cab on frame now for final cab and fenders alignment, to finish body work. Included photo of 66’ cab and finders color cut in.
Les
Old 07-31-2020, 10:08 PM   #364
aotte1
Update on 64 K10, waiting for paint and body work.
Starting on another 64 to 66 K10 project. It is a 1966 GMC Suburban 4WD.
Taking it apart currently. Needs lots of work, however, some good points for it too.
Not a lot of rust on frame/suspension, and it is very original. Body has typical rust, and maybe more. Mainly concentrated on lower part of body, along with hood and fenders. The new project came from board member “southern parts”. A big thanks for getting me the 1966 GMC suburban K10.
Old 08-04-2020, 07:23 AM   #365
Moscowmule
Hey Les, is there any chance i could get you to send me a close up shot of your radiator core support brackets and some actual dimensions for them ?Mine are shot so bad I cant even get any reliable measurements off them.
thanks
Ps they are the ones in your last pic of the frame and very nice to see your back at it
Moscowmule is offline   Reply With Quote
Old 08-04-2020, 02:18 PM   #366
61K10
61K10's Avatar
Looking good Les, and its good you have a helper most kids won't get off there phones. Haven't did much to my tk still need to change the trans. Hot weather and old age don't get along lol! I think my pto is part of my trans noise, thought of removing the winch but i would need some frame horns as they were cut off for the big bumper.
take care Les----------kimble
1961 chevy K10
Old 09-11-2020, 11:16 PM   #367
aotte1
Billy,
Yes glad to help, may be a few day, Truck is in storage . Will need to visit it.
Let me know any specific dimensions need and will get them.
Photos below, 66’ GMC K10s Suburban.
Les
Old 09-11-2020, 11:37 PM   #368
aotte1
More photos:
Let me know if you need more photos. These are V8 3 row radiator.
Also should be able to get V8 4 row radiator Cross member if needed, will need to dig for it.
Note: some of the measurement waste an inch for accuracy.
Les
Old 09-11-2020, 11:45 PM   #369
aotte1
Hi Kimble,
Good to hear from you, have same issue, still hot and humid here. Waiting for cooler weather to start on 66’ GMC floor rust. Hopefully in a few weeks.
Making some progress of frame/suspension. Working on axles and TC inside in AC too.
You remember this process too, on front/rear spring shackles, bushings and pins. Removing, cleaning, replacing worn out parts. All that done now installing, one rear done. Thanks for all your help in past, along with your very helpful build ( 61K10 build ).
Les
Old 09-14-2020, 06:41 AM   #370
Moscowmule
hey les thanks alot for the info and the effort it was very much appreciated. unfortunately the wrong brackets. the info i cant seem to find any where are
the dimensions a for the heavy steel brackets that are the forward most outboard brackets on the frame they are the ones that look kinda like the cab mounts brackets
again i very much appreciate you going to storage for me i feel bad that it was a wasted trip
thanks bill
Old 09-19-2020, 04:49 PM   #371
aotte1
Bill,
Will retry to get them for you. Are yours 2 or 4WD, they are different on C and K trucks. Assume yours are for K truck.
Should have dusted off the frame.
Les
Old 09-20-2020, 12:02 AM   #372
aotte1
Bill,
A few more photos, of 1966 K10 core support crossmember frame mounting brackets.
Need to reference 2nd photo for you, will do.
Any other dimensions needed?
Les
Old 09-22-2020, 06:35 AM   #373
Moscowmule
Man you are the best thanks for that sorry I didn't see it sooner I'm still at sea and fishing is very slow weather is bad and internet connection is almost non existent .
the only measurement i don't see is the overall height but what you provided should at least get me started on a little "government project" while im out here
thanks alot
Old 09-22-2020, 08:47 AM   #374
raylube
raylube's Avatar
I am going to try these for my 64, I think other than the 4 mounting bolts vs 3 they work.https://www.jegs.com/i/Key+Parts/576...hoCyBsQAvD_BwE
Old 10-10-2020, 04:52 PM   #375
LT7A
This is a very interesting build. Really enjoy the thoroughness and methodical approach. I'm also interested in your other two builds. Are yoU doing build threads for them?
